Question about Bose Additional Wave radio II remote control - Graphite Gray Remote Control
For the love of god, do NOT listen to Paul Sager - HDMI is *always* better than component. HDMI is a pure digital signal, offering the cleanest possible signal you can offer an HDTV. Component wiring is analog, and while good, it is by no means as good as HDMI.
Posted on Dec 29, 2013
SOURCE: Remote Control does not function
the conducting ink coating inside the blisters is gone. carefully open the top portion,which is stuck like an adhesive tape conducting ink black or brown is available with a hobby electronic shop put a coating on the inside of the blister let it dry stick the cover again. p.s. bose service will tell u it is not repairable
Posted on Feb 26, 2009
SOURCE: I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Posted on Jul 05, 2010
SOURCE: I cannot get the volume to go up or down...it is
If you have other (Universal) remotes in your home try programming one of them to operate your Bose.I have a different Bose system for my TV and can operate the on/off and volume from my universal remote. The code I use is 440, I show another code of 302 that may work.
Posted on Nov 28, 2010
SOURCE: Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
Posted on Mar 06, 2011
Oct 13, 2015 | Proscan 26LB30QD 26 in. LCD HDTV
on May 23, 2009 | Insignia 42" LCD Flat-Panel HDTV
on May 23, 2009 | Insignia 37" LCD Flat-Panel HDTV
Jul 19, 2014 | Televison & Video
Oct 21, 2013 | TCL LE32HDF3300 32 Inch LED LCD HDTV
on May 23, 2009 | Insignia LCDTV26 26 in. Television
Jun 06, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Mar 29, 2009 | Jensen JR400 Remote Control
on May 23, 2009 | Insignia IS-LCDTV32 32 in. Television
1,134 people viewed this question
