If you enter the BIOS menu just before the system boots up, you can choose whether to boot from DVD ROM, LAN, USB etc. Just select what you require and save it.
Set the bios to the default settings and it will boot from the cd first then the hard drive.If that doesn't work your cd drive eye may need to be cleaned or the cd drive is bad. The install disc your using also may be corrupt.
1. Is the boot sequence in BIOS set to boot from CD or DVD, if not I would suggest you to go to BIOS and change the boot sequence to boot from CD and try to boot from the CD
2. Is the computer custom built or OEM built?
3. What is the model number and who is the manufacturer of the computer?
4. Have you made any changes to the computer by installing any new software or hardware?
5. Since when are you unable to boot the computer normally?
6. You need to get Windows Vista DVD to perform further troubleshooting either to scan the computer or to perform repair install, I would suggest you to contact the computer manufacturer to obtain vista DVD.
Thanks
