Computers & Internet Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Travelling thru Vietnam my Asus ULV30 stop charging and powercord stop supplying power, was working first week suddenly no power.
Anonymous
Level 3:
  • ASUS Master 32,281 Answers
  • Posted on Dec 19, 2010
Anonymous
ASUS Master
Level 3:
Answers
32281
Questions
Helped
7905974
Points
102259
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
2answers
I cannot turn Asus netbook on - not charging, no indicator lights on
Could be a duff battery, does happen. are you. do you have a ampre meter to check charge
Suddenly power failure ,when the power returning the pc switched ON the SMPS fan and PC also not working.
My advise to you is to never turn of your computer!
the constant start and stop put stress on your power supply not to mention dust build up and if not properly cleaned the startup process can cause a short which I've seen so many times.
I have a computer which is 8 years old I never wanted to turn it off but leaving for two weeks vacation I turn it off. On my return the startup it shorted yeah dust build up.I had to replace the power supply, still running now. (A warm drive is a happy drive)
I have an ASUS X83V. All of a sudden the charger that came with the computer stopped working and the computer went dead. I purchased a compatible charger for the computer and it worked for about a week...
From the information you gave, my guess is that there's a problem with the power supply section of your laptop, or the chargers that you're buying aren't actually compatible... but it's more likely that it's the first case. If the laptop is under warranty, you should contact ASUS and get them to repalce the motherboard. If not, you could spend a lot of money replacing power cords every week. Good luck!
Hello, I have an ASUS KBV-MX motherboard. Suddenly from the last few weeks i am not getting any display. When i start the system, it will go through till the windows log and then suddenly it gives an...
Replace your power supply unit with a better wattage rate. BSOD is sometimes cause by an intermittent power supply.
Thanks for using Fixya.
Panasonic DMc-ft1 stopped working, HELP!
The guarantee is just a piece of paper unless you can show proof of purchase to validate it, sorry.
Ive got an asus laptop and it was working last month, but recently when i turn it on it suddenly turns off
some times this problems are rarely occured of becuse your hard many no booted properly or my be problem with your laptop battery it may not be properly charged charge continusely for one hour and try again if problem is still there contact your nearst asus service center or goto www.asus.com and post your complaint there. thats all
ASUS 1005HA netbook suddenly always restarts
Good day sir/maam, the sudden restart of you notebook, may be cause by a sudden fluctuation of AC mains, it could also be cause by other sources such as nearby machineries. which boils down to the notebook's power supply module. Is it capable of supplying good descent power to your notebook. Try moving to other places, such as well at work or any place where you think there is stable power. Hope this helps. thanks
1helpful
Asus p4b266-c won't start up
Check the power supply. Take out the SMPS and replace with a working one of the same wattage and check. It happened to me once........sodeep
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
