Apple iPod touch Logo
Posted on Dec 19, 2010
My ipod touch is disabled due to entered wrong password so many times.how to enable it??
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Dec 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
3554
Points
57
You can unlock your IPOD Touch passcode or password by following these simple steps.
  • Connect your IPOD Touch to iTunes
  • Press or Hold the power and home keys 10 seconds.
  • Screen goes black, now release the power button
  • Make sure you do not release the Home key until your iTunes says "We have detected an itouch in recovery mode."
  • After this its simple all you got to do is a simple restore using your iTunes
  • bmyriam28 Apr 10, 2011
    thaxxxxxxxxxxxxxxxxxxxxxxxxxxx a million times i though iwas going to lose that ipod
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Feb 01, 2009
SOURCE: ipod touch password
connect to itunes hold the power button and the home button until screen on ipod goes black keep holding the hme button until itunes says that it detected an itouch in restore mde then you have to do a system restore n itunes
I've forgotten the password to my 5th gen Ipod, but when i plug it into the computer it says turn off 'fing my ipod'
If your iPhone is disabled due to enter wrong Password than Launch the recovery mode after Turn off your device and then Restore the device in iTunes with the help of technicians. For iPhone recover http://support.apple.com/kb/ht1212 and more guidance with Mac Help .
Itouch disabled
When your iPod Touch displays a message telling you to connect it to iTunes, it may be in recovery mode, or have been disconnected in the middle of an update.
To get rid of the screen, you must reset your device. If in passcode mode, an iPod Touch must be manually unlocked or fully restored to get back to the home screen.Forcing a Reboot
When your iPod Touch is stuck on a screen that is instructing you to connect with iTunes, a normal restart will probably not work, as the hard drive has become frozen.
You can still, however force the iPod to reboot using a process called resetting.
To reset an iPod Touch, hold down the "Sleep/Wake" and "Home" buttons at the same time until an Apple logo appears, indicating that the device is rebooting.
When an iPod Touch reboots, it always goes back to the lock screen. Passcode mode will still be enabled.
Unlocking With the Passcode
If you know the passcode for your iPod Touch, slide the "Slide to Unlock" arrow and then enter your code on the next screen.
Upon entering your password, you will be directed to the device's home screen. If you enter the wrong password too many times, it will become disabled temporarily.
The iPod Touch can also be set to erase all content after 10 incorrect passcode attempts if you previously enabled this feature, don't attempt more than 9 entries.
Unlocking Without Passcode If you have forgotten the passcode to your iPod Touch, the only way to unlock the device is by restoring it.
Restoring an iPod Touch returns it to the factory settings, meaning that any settings, applications or music you added to the iPod are removed.
Once the device is restored, you can re-add your downloads and other information using the backup copies in your computer iTunes program.
The passcode setting will be disabled unless you manually enable it again.
Consideration
If you don't have a backup of your music and applications in iTunes on your computer, you can also download another copy from the iTunes Store or App Store on your device after a restore.
Any photos that are deleted during restore, however, will be lost forever if a backup does not exist.
Always back up your information via sync on a regular basis to avoid this problem.
3helpful
2answers
How can I unlock a disabled ipod touch?
Step 1:
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer. It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen. If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled. To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer. Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window. Click the "Restore" button. If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup. If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings. Wait while iTunes syncs with your iPod Touch and restores the device. iTunes will prompt you when this process is complete.
My ipod touch has disabled from entering wrong pasword serveralk times
Hi there!
If your iPod touch is disabled due to too many unsuccessful attempts to enter the password, you can unlock it by connecting it to the last computer you used to sync it.
Hope this helps.
My daughter was playing with my i pod touch.i cant get it open.i do have a passcode.but is says.i pod is disable.how can i get it unlocked
The iPod touch was disabled because the wrong password was entered too many times.
Connect the iPod to the computer you normally sync it with. After that you will be able to unlock it.
2helpful
2answers
Ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
1helpful
Im trying to enable my disabled ipod touch,how can I?
ipod touch disabled might be due to incorrect password attempt or something else.
use this link from apple:
http://support.apple.com/kb/HT1212
God Luck, if it fails, comment back
Ipod touch password
29helpful
8answers
How to reset password on itouch
how can i reset my ipod touch when its disabled
2answers
Ipod touch disabled
If you repeatedly enter the wrong passcode, iPod touch will be disabled for longer intervals, before you can try again.
So you have to give the touch back and have it connect with the original pc. Or then loose all the files with a update/restore.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
