Plug it in then push power+volume up for 30 seconds or until a message appears for 1 second easy to miss so dont blink until you see it then let go and press power button until it boots
Testimonial: "As Soon as I tried it It Worked!! Thank you so much!!:) Teething Twins and A bad Singing voice not the greatest thing to sleep:)"
And if that doesn't seem to work?
Please advise what to do if pushing power volume for 30 seconds doesn't work and no messsage appears. We've tried this several times to no avail, and my daughter--who received this as a gift---is heart-broken!
My ereader is doing the same thing! I read it on Tuesday morning, battery was almost dead so I put it up, plugged in to charge. Then when I went to read it that night, nothing! Won't turn on, just the green light saying it is fully charged. I tried resetting it. I tried the power and volume buttons at the same time for 30 seconds and nothing is working! Please help, I love my ereader!
We are having the same issue. Will try the reset procedure described above and report back.
I had mine go dead and I read all the ways to restart - None worked. I read that someone found if you let the battery go dead (Took one Day) , then plug it in, it will come back on - I tried it and it worked great - I am trying to find the guy and thank him/her.
how do you get the back off?
to remove the back there are 4 small black things over the screws there is one on each corner i too mine apart cuz the screws that held the battery down fell out and i had to put them back in so i took it apart myself
Has anyone figured this out yet? I was reading on it while it was charging, no problems, I looked away for a few seconds and when I returned there was NOTHING! It won't turn on with or without the charger plugged into it. Tried holding the power button with and without the volume button for 10 seconds up to 2 minutes and saw no change. Can't find a solution anywhere online. I've had this about 2 months and have successfully charged it a dozen times. What is wrong? How long is the warranty????
Hello all Digital lovers, Sure fix look at the back about a 1/4 of the way down at the first crack after the Pandigital logo if you put your finger dead center and press down the back will come off and you can unplug your batt and then plug he power cord in and power up. Replace cover and enjoy... Hayden Weekes
OMG Hayden (hrweekes), that worked! I can't believe it! I just pushed where you said (had to try it 3-4 times, maybe I didn't have the right spot) and then it just booted up. I did this without anything plugged in and the back didn't come off.
I have the 7" Color Multimedia eReader and I've only had it since Dec. 2010. It wouldn't start up with the battery charger plugged in or with the USB cable connected to the computer.
I'm amazed! WooHoo! LOL!
WOOOO Thank you Hayden!!! It worked for me as well...I wasnt sure how to remove the battery, just unplug the little black white red cord (which i was initially nervous to do but it slides right out)
It worked!! Im into an intense book and was dreading having to wait until my battery dies!
Thank you so much Hayden!!
I was able to get the back off, but the battery cable won't let go. One person said it slid right out. Mine is stuck. Any ideas?
Thank you so much. It worked, but I will add that I also had to press power, reset and volume for thirty seconds and then I had to press reset again to get rid of a triangle, but it works great.
My white pandigital won't turn on it has this triangle with an exclamation mark, and a green thing on the side?? What do I do?
Plug it back in. Hold the power button and the house button until it comes back on.
