Question about Nokia N70 Cellular Phone
Hello sir/madam , in my nokia n70 device the left navigation key and the buttons 1 and 3 does not work . up and down navigation keys are also not working . kindly tell me the right solution
Posted by friend_436 on
Jabbar Oviedo
    New Friend:
  • 17 Answers
Hi Friend!
The best advice I can give is that you bring your phone to a technician for check up. You might not want to tinker with your device on your own and end up with a dead unit altogether but if you wanna give it a try, the problem somestimes is a dirty or corroded keypad. Remove the membrane attached to the keypad and use a cleaning solution such as a paint thinner to clean the keypad surface. Use a piece of cotton with the solution. Another thing you should also check is the keypad connector. Check if it is properly aligned.
Posted on Dec 20, 2010
N70 ok to program but no power
Hello:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Feb 01, 2013 | Nokia N70 Cellular Phone
Hello sir my name is makarand kelkar i'm 4m mumbai my cell phone is nokia 5130 my cells kye pad is not work properly means navigation key of left & right & also go to key and music kye...
The Navigation key set can be changed, it will cost around Rs.250.... Just take it to a mobile repair shop and ask them to change the key navigation board. It is very simple, even you can buy the spare and change it yourself... But the music keys I'm Not sure they will work or not, because it is a well known complaint in Music series of Nokia and nothing can be done properly(so don waste time in spending money for music keys)...
May 13, 2011 | Cell Phones
Hang and i want to format my phone
Welcome to fixya.
Please follw this steps for format your nokia N70
1. Switch off your Nokia N70 phone.
2. Hold down the following three keys, Green (call button) * Key, and Number '3' key
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Hope this solves your problem. Thanks for using FixYa.
Feb 20, 2011 | Nokia N70 Cellular Phone
How to format the phone manually
Hello
Here's how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone 2) Press and hold these 3 keys together: -green dial key -the star key(*) -the number 3 key 3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Hope this helps
Jan 17, 2011 | Nokia N70 Cellular Phone
Nokia n70 not start properly
sir, its due to virus attack, just follow the steps below,
1. Switch off your phone...
2. Remove SIM card & memory chip...
3. Now press & hold keys - 3,*,call green) ...
4. Then without leaving these three buttons press power button...
5. Formatting task will be started...
6. Remember its a very rare trick....
Dec 28, 2010 | Nokia N70 Cellular Phone
How to format nokia n70 music edition
Hello there,
If you have not found a solution yet, here is the correct way to do a FULL format of your N70.
1. Make sure your phone is fully charged to handle the formatting process.
3. Turn off your n70.
4. Press and hold the following keys at the same time:
a. Green dial key
b. * or the star key.
c. the no. 3 key
5. Press the power on to switch on the phone. Take note: Hold those keys until you see a formatting word on your screen.
6. Wait for a few minutes until formatting is completed.
Hope this helps.
Jul 09, 2009 | Nokia N70 Smartphone
Nokia N70 Menu not opening
ok i think sure you phone need soft waer again but in this case can not you do it alone because it need tornado or jafa box
Feb 18, 2009 | Nokia N70 Cellular Phone
Lincese key of smartmovie 3.41
guys here's your smart movie license
356406015251423
key: 10661
352061028048060
key: 35786
356996011925491
key: 42273
352913022128159
key: 22385
353954012048592
key: 62545
354835017716417
key: 36983
358064010816944
key: 23080
353094024317667
key: 24355
354829027127202.
key 10536
356406012565718
key: 44341
35336000229197
key: 29198
354813017111004
key: 30032
359362004494093
key:25795
Jul 17, 2008 | Nokia N95 Cellular Phone
LCG Jukebox license code
hey sir,i have a N73 ME with IMEI 358973010317986 Can you please me the license code of LCG Jukebox 2.41
Apr 06, 2008 | GPS
I need license key of N70S, MP3
original licence keys are provide only with genuine prchase to get full working softwares for n 70 got to www.funmaz.com there u can see a section named mobile in the top there all softwares are avilable
Jan 17, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
Ekse
Zaid Anarwala
Zaid Anarwala
SANTHOSH
