Question about Hitachi CMP4201U 42 in. HD-Ready Plasma Television
Humming noise from the back of the display. - Hitachi CMP4201U 42 in. HD-Ready Plasma Television
Posted by timothy_flan on
Chi Chu
  • Hitachi Master
  • 8,457 Answers
This problems are the causes by of those power supply tranformers in power supply board are not seatted or uneven gaps in the board itself have those highvoltages flow going through it,that where the humming sound came from.This problems just anoiding mostly,want to solved it.Trie website like Ebay.com to buy a whole refurbish power supply board for the replament.
Posted on Dec 19, 2010
Why do my desktop computer speakers have a humming noise all of a sudden? They were turned off for a couple of days .
Check the speaker cables for connectivity. Be sure to securely plug in the stereo jack/s at the back of your pc
Jul 21, 2014 | Logitech Audio Players & Recorders
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
Reason for humming noise even after changing wheel bearings of car
Depending on how the noise is affected by your driving, it could be an axle joint or the differential in the transaxle.
If it is coming from the back instead of the front you may still need hub bearings.
Sep 03, 2012 | 2005 Nissan Sentra 1.8
No agitation. Humming noise
Check if the belt is fitted correctly and not broken.
Nov 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My TV makes a humming noise and the display on channels that are broadcasted in HD is not working.
the reason for it not displaying HD channels would be the Tuner itself, The humming from the back would be a fan that is dirty from dust or its is given out.
solution for the humming clean out the fan! check fan to amke sure its doing the right RPM rotations per min. For the tuner this would need to be looked at and tested by a Tv repair person.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Hum in the audio - 32'' Proscan 1080i
does the hum occur when playing a dvd or only when watching tv ? if the hum occurs only when watching tv, i would like you to disconnect the cable line from either the wall or the back of the cable box and see if this hum disappears. if the hum disappears call your cable company. you have what is called a " 60 cycle ground loop ". hope this helps.
Jan 20, 2009 | Televison & Video
I replaced the light bulb, now it displays -F6- and pushing any button causes a humming noise.
I left the unit unplugged over night, plugged it back in the next day and still had the same problem.
Oct 13, 2008 | Roper Microwave Ovens
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Hitachi CMP4201U 42 in. HD-Ready Plasma Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
