Question about RCA P52939 52" Rear Projection Television
I can't get my tv on antenna 1 or 2 its just showing a blank screen. i need to know how to program it without being able to see the prompts on the screen
Posted by ronaldmsmith on
Anonymous
    New Friend:
  • 88 Answers
There should be an input button on the remote and tv that should fix this
Posted on Dec 19, 2010
My tv screen is snowy and I get the prompt: weak or no signal...check the antenna cable connection (I have done that) and run auto program ( have done that).
all channels? outdoor antenna? if indoor antenna try moving antenna around to find the best spot, also you need to know from which direction your signal is coming from and how far you're from tv station, if too far you may need a signal booster, and make sure your antenna is for digital signals. same goes for outdoor antennas.
LC32D44E
Tuner fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
2answers
I need to know my ip adress and all that stuff?? help please
Inorder to find the ipaddress of your computer follow these steps,
1. Click on start? Go to All programs? Accessories?Command Prompt
2. You will find a black screen which is the Command prompt
3. In the command prompt you will find a blinking cursor , there you type in "ipconfig/all" (without cotes)and hit enter.
4. You will find ipaddress, subnet mask, default gateway , mac address/physical address and all other information of your comp.
Thanks in Advance!
With Regards,
Prema
1helpful
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Green screen on Toshiba 34N9UXE
you can have a bad CRT, a bad chroma module, either one can show the symptoms you are describing. You will need a TV repair tech for the right diagnosis.
DVD PLAYS FINE BUT GET A BLANK SCREEN WHEN USING THE TV WITH SAT
Your signal may be low. Try chaning the channels and adjusting your antenna. I hope this solution is helpful. Please take a moment to rate this solution.
[2] 811 dishnet receiver
you need to program one remote with a different code, power off or unplug one of the receivers. Go to the other receiver and hit the system info button at the receiver. Now read the remote code at the bottom of screen would be a number between 1 to 15. Program the remote for a different code than what it shows. Push and hold down the sat button on the remote and leave go light will blink, enter code say 14 and the pound key. You will see the light blink 3 times on the remote. Now that code is entered in the remote now with that system info screen up on the tv watch at bottom where code is and hit the record key on remote and you will see it change to 14. All done . now just plug back in your other receiver.
2answers
Digital Reciever Issues
I have the exact same problem.Check this out. http://www.fixya.com/support/t209330-lg_dat_250 Unfortunaley, for temporary use of other channels other than abc & abc2, you need to pull out the antenna lead when it is trying to program those stations back in. My serial number starts with 601, does yours?
1helpful
2answers
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Open Questions:
See all RCA P52939 52" Rear Projection Television Questions
RCA P52939 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
