Question about Samsung HL-S4266W 42" HDTV
The info states this TV has an HDTV tuner (ATSC), however I am unable to tune any digital channels which are broadcast via our cable provider (not offered on whole number channels, rather decimel points 4.1, etc). These channels do not require de-scrambling. Is this tuner insufficinet in this capacity or am I missing something?
Posted by kryan337 on
Anonymous
    New Friend:
  • 167 Answers
You need to reset you tv to factory mode, by pressing tv off---mute 182 power---go to options and look for *reset to factory* them wait until the process is done.
Posted on Dec 19, 2010
  • kryan337 Dec 19, 2010
    These steps did send me through the initial setup again, however there are still no digital channels - also no evidence that they could exist on this TV. Generally, scans show the status/results of the scan (x number of analog channels found, x number of digital channels found). The channel manager in the menu does not show any digital channels either (hidden or shown). It appears it could work with a cable box which would do the tuning then the TV acts only as a monitor. I am concluding this TV is incapable of tuning a digital channel.
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
Can a toshiba 28z07b be digitally tuned
Your TV set has a 181 Channel Tuner and 100 Programme Positions..
Over the air signals (analog and digital) are free but require an special antennas for Digital reception and reception depends on your where you live and other factors.
Additionally Cable and satellite signals require you to connect a cable to your
TV tuner and a subscription and cable box for premium channels including Digital channels..
While all l TV tuners have the ability to receive over the air TV signals,
not all tuners can receive high definition (HD) signals. In North America, all
over-the-air TV is now broadcast in digital quality (ATSC).
ATSC is the over the air HDTV standard for North America and is currently available
in over 200 cities in the United States.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 29, 2011 | Toshiba Televison & Video
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
I just purchased a used Sony KDL-V26XBR1 that cannot tune the digital channels over our cable or any signal on the over the air input. Our Samsung, same vintage on the same cable can tune the digital...
Greetings - Your Sony has the standard tuners for a current HDTV, NTSC (analog), QAM (cable), and ATSC (digital/HD) broadcast..
There's something going on with the Sony TV. It's a pretty high end TV so it might have some additional features that require you to do something different (I doubt it) but make sure you've been through the manual.
If you didn't get one with the TV you can download a PDF version HERE.
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 12, 2011 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a nspdp42 plasma and i cant affort cable and want free tv. is there a analog to digital converter in the unit already? the model # is 801rmd2237770 Thank you
The Insignia NS-PDP42 Plasma HDTV has a built in ATSC/NTSC/QAM tuner.
In short, yes, it does have a digital converter built in, but you will need a antenna capable of receiving digital broadcasts. You can find these at Walmart for $15 to $60.
Mar 05, 2011 | Insignia 42" Flat-Panel Plasma HDTV
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
We have a phillips model #32PFL5332D/37 it has a flat screen. Is it digital or analog
Yes this TV should tune to both Digital & Analogue reception. See below I have copied an extract from the Philips technical site which gives you verification that this has digital capability. Hop this is of help to you. Next to analog NTSC broadcast reception, your TV has an integrated High
Definition TV tuner which receives, decodes and displays terrestrial ATSC and
unscrambled cable (QAM) signals.
HDTV quality is only reproduced when a broadcaster or cable provider broadcasts
HDTV signals.
Jul 24, 2009 | Televison & Video
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Dec 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Samsung HL-S4266W 42" HDTV Logo
211 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
