Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a craftsman opener model 139.53513 and I purchased a Craftsman Model 139.53876 wireless keypad. How do I program this to work with the 9 dip switches on the opener?
Posted by Ed Rieker on
  • deadcandance Jul 16, 2019
    Ok so I am in Canada and I bought this used Craftsman remote keypad that you install on the side of your garage door on the outside of your house. I assumed that as long as the keypad brand was Craftsman, Liftmaster, Chamberlain or Wayne dalton, that any keypad of these brands would work with any of these brands of garage door openers. WRONG!! I spent $40.00 for a used keypad only to find out that it is not compatible. So to avoid you all from making the same mistake...here is what I learned or know now. First off it is very important to try to find out what colour the square plastic learn button on the actual garage door motor was that the remote keypad you are looking to buy , was used with. It is also a good idea to find out what the FCC ID # is on the back of the remote keypad you are looking to buy.Once you have the FCC ID# for example mine was FCC ID# HBW1631. You can type into Google searchbox "FCC ID# Lookup" and that will take you to the FCC's website. If a search box does not automatically pop up, you scroll on the left side of the page and look for "FCC ID Search". A box pops up. The first box is called "Grantee Code (first 3 to 5 characters)...mine was HBW. The second box underneath is called "Product Code (remaining characters of the FCC ID#).......mine was 1631. Hit search and a result should pop up, In that result you see a lot of info but at the far right you will see the lower and upper frequency range of your remote keypad you are either selling or planning to buy. Mine was 315MHz upper and lower range. So that means that my remote keypad will only work with garage door motors that operate on or between a lower and upper range of frequencies that include 315MHz. Now we have to find out what frequency the garage door motor is. If you are buying the remote keypad....as the seller what colour the Learn Button is on the garage door motor. For my remote keypad I bought, it worked with a Green or Purple Learn Button on the motor. So the keypad I bought would not work with my motor with a red learn button. To find out what frequency your garage door motor operates at, you can either call customer service for the brand you own and give them the model number.Or Google the model number to search what frequency the motor operates at. I had a hard time googling it so I just called Chamberlain customer service and they told me my motor is 390MHz. So now I know the frequency range my garage door motor operates within, I can look for used remote keypads, ask the seller what the FCC ID# is, then type it into the FCC ID Search Lookup website to see if the remote keypad frequency falls within the operating frequency range of the garage Door Motor. Hope that helps a bit guys and gals. Kev
Don Maggard
    President:
  • 3,197 Answers
The remote you got is billion code technology and will not work with your opener.
Posted on Dec 20, 2010
Cannot find compatable keyless entry for 139.53647SRT craftsman garage door opener-the one I purchased always erases my remote for my vehichle when I try to program it. What am I doing wrong, seems like...
The keypad listed for your model is 53876. If this is the keypad you presently have and the remote no longer works after you program the keypad it could be the remote that is bad. Sounds strange but it is true. Make sure you are programming the keypad like this.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Some reason keyless entry won't open my garage door. I have directions to change the code but, there is nothing in the manual if your code no longer works. I have changed the battery, pulled the plug on...
If that keypad quit after working since 1997 and a new battery didn't get it going it has just gone bad. The model number listed for your opener is now 53876.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
I'm trying to program a remote to the sears craftsman garage door opener model 139.53513
The model number for the remote that works with this opener is 53778. Make sure the dip switches are set exactly like the switches on the end of the motor unit.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Ladies / Gentlemen: I have a Craftsman 139.53975SRT1 Garage Door Opener. What is the correct keyless entry pad for this opener? Will a 139.53876 keyless entry pad work with this opener? Thank You! ...
The correct keypad for your opener is 139.53684. The 53876 keypad is an older technology and will not work correctly. If you program it you will find your remotes no longer work and if you reprogram your remotes the keypad will not work.
Sep 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman 41a3625 garage door opener with a #53876 wireless keypad. I just bought the house. How do I get a new code. They did not leave the old code.
On the back of the motor unit near where all those white wires go you will find the smart/learn button. Press and immediately release this button and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jul 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
I want to re-program my keyless garage door.
Mulleta,
If you look on the back or side of the garage door opener you will see a small square red/orange button.
Push the button one time, and you will see an amber LED come on. Go to your keypad enter a four digit (of your choice) then press and hold the the enter button until the garage door opener light flashes and you hear a clicking sound. You can release the enter button and it will be reprogramed.
Apr 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to set dip switches on remote for Chamberlain Liftmaster 1000
I would go with a chamberlain clicker on this issue. These remote are phased out and the 9 dips don't work well with them. Thanks BB
Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
478 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
