Canon iR 3100 CN Fehlercode 000602-0202
Hdd error - call service!!!!
But if you want do something on your own:
A:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HDCHECK*.
3) When done, turn off and then on the main power.
B:
1) Find the appropriate CHK-TYPE from the table 'HDD Format' ; then, make the followingselections, and type: COPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CLEAR.
C:
1)** Start up the machine in normal mode (i.e., turn on the main power while pressing the 1 and 7 keys ; then, make the following selections, and press the OK key:
COPIER>FUNCTION>SYSTEM>DOWNLOAD).
2) Perform formatting of DOSDEV4 using the Service Support Tool.
D:
1) Replace the main controller (main) board.
2) Remove the image memory (SDRAM) and the boot ROM from the previous board, and attach them on the new board.
E:
1)** Start up the machine in safe mode (i.e., turn on the power while pressing the 2 and 8 keys).
2) Format the HDD (ALL) using the Service Support Tool, and download the system software (SYSTEM, LANG, RUI).
F:
1)** Replace the HDD, and start up the machine in safe mode (i.e., turn on the main power while pressing the 2 and 8 keys).
G:1) Make the following selections, and enter '1': COPIER>FUNCTION>SYSTEM>CHK-TYPE.
H:
1) Turn off the main power; then, turn on the main power while pressing the 1 and 9 keys (so that the machine will automatically start its remedial program*, turning
the control panel solid black).
2) When done (i.e., when the control panel turns white), turn off and then on the main power.
If the machine does not run its remedial program in response to the foregoing step, go to E.
I:
1) Find the appropriate CHK-TYPE in the table "HDD Format"; then, make the following selections and enter CHK-TYPE.
2) Make the selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK*.
J:
1) Make the following selections, and enter '4': OPIER>FUNCTION>SYSTEM>CHK-TYPE.
2) Make the following selections, and press the OK key to perform: COPIER>FUNCTION>SYSTEM>HD-CHECK (1 to 5 min).
* Takes about 30 to 50 min.
** As necessary, ask the user to use the RUI to collect address book data, transfer settings, and user mode settings.
