Yes, if bulb was low price and was installed in old lamp casing then it is bulb that is not good and creating too much heat that exhaust fan can't throw out to make projector cool enough so temp sensor activates and send over heat signal to system control chip thus projector shuts down.
Please install original lamp that comes with casing to solve this issue.
If lamp was original then check exhaust fan that might be running slowly due to stiffness in bearing so temp sensor finds over temp in projector.
Hope these info will help you.
Thanks.
I also had set the 'high altitude' on so that the fan runs on high all the time. Still needs the floor fan. The internal fan does appear to be working as I can hear it.
Nope. Tried Optoma certified lamp w/cage. Still overheats without external fan and high altitude setting. I changed my mind about paying for a solution, too many horror stories in cyberspace about this. I'm very techncally adept and have tried all obvious options.
