Chornic hope you Enjoy garden watering and make garden watering easy and convenient.
1)Compact, lightweight, tightly leaves a pleasing impression on you
2)Solid brass fittings ensure a longer and working life and no more worries about leaks.
3)Newst and improved aluminium clamp fixed connection and crush resistant metal fittings all prevent leak.
4)This hose is a revolutionary hose that automatically expands up to 3 times its original length when the water is turned on and snap back when the water is turned off, suitable for male and female.
5)This double layer latex core hose is one of the strongest and most durable expanding hoses available on the market!
6)This hose is widely used,best for Lawns, Plants andamp; Shrubs, Washing Cars, Dogs + Pets, satisfy your different needs. https://www.amazon.co.uk/Chornic-Expandable-Flexible-Aluminium-Fittings/dp/B01JO4I4HS/ref=aag_m_pw_dp?ie=UTF8&m=A32I5R32CFB6Z3&th=1
Yes, this is a problem for our Nexxt dryer as well. This may work for you. I took an old garden hose, cut about three feet off it, then took a cap from spray paint can, cut a hole in it the diameter of garden hose. Put the hose in the cap. The spray paint cap fits nicely on my shop vac. Took the shop vac in the laundry room and attached the spray cap with the garden hose inserted and vacuumed the lint from the slot using the end of the garden hose. Worked pretty well. If you don't have a shop vac you may be able to stick a flexible hose in the end of you home vac and hold it with your hand to seal it. That should be able to remove most of the lint. Good luck.
