Question about Garden
No problems yet, I would like to have a manual for a STIHL TS400.
Posted by rilinc on
Anonymous
    New Friend:
  • 40 Answers
Have you tried to search STIHL online, try
www.stihl.com
www.stihl.ca
hope this helps
Posted on Dec 18, 2010
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 | Stihl Saws
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Jan 30, 2018 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 throttle stuck open and trigger stiff
Hi Mate, Got the same problem, Have found the service manuals for the TS400, and looking at it I think it's a problem with the throttle rob connecting to the carb.
Did you manage to fix it ?
CheersSteve
Jun 14, 2012 | Saws
Wiring diagram for a stihl saw ST400
There is no diagram. it is a simple system the coil for the plug has a kill wire that runs up to the thumb switch.
page 31 of the service manual shows the connectors.
Make sure the wires are not rubbed through.
I am a Gold certified Tech for Stihl. Feel free to ask any other questions you might have.
Jose
link to ts400 manual
Jan 12, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Instruction manual for a still ts400 saw
I just googled Stihl ts400 manual and it was the first hit!
http://www.stihl.ca/manuals/0458_338_8221_0_01.pdf
Oct 21, 2010 | Garden
Need to know belt size fo the stihl ts400 concrete cutoff saw
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Stihl ts400 will not stop, it carries on running. Where can I get hold of a service/repair manual
Stihl guards their service manuals making them only available to dealers who service Stihl.the kill switch is not making contact. a t25 torx should get you to the point where you can determine if my theory is correct.
Feb 26, 2010 | Saws
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
john h
ray gallant
