Question about Samsung SCX 4521F All-In-One Laser Printer
Samsung scx 4521f display no cartridge - Samsung SCX 4521F All-In-One Laser Printer
Fix It Fast Electronics.
  • 108 Answers
On the cartridge near the reset fuse there is a tab that pushes on a switch in the machine to tell the machine the cartridge is present. If the cartridge is dropped the tab can break off rendering the cart useless.
Posted on Feb 23, 2011
Cannot print 4521f
cartridge inserted poriton ( fuser unit bottom portion ) you can see a small "L" shadped liver fixed with a screw, removed that from there and try with new cartridge.
Jan 15, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Samsung printer scx-4521f need smarthru4 scanner software
need a reliable site to download smarthru4 scanner software for Samsung printer scx-4521f
Oct 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to solve CRU duse Error in Samsung SCX-4521F Printer?
From Samsung site:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
Works for SCX-4521F
If this will not make the message dissapear it means that the actual fuse is burned out and need to be replaced ...This is how the fuse looks like
http://www.easterntoner.com/product_info.php?cPath=112&products_id=569&osCsid=9d77e00d739b433bf68d25e0335979f9
Jul 11, 2011 | Office Equipment & Supplies
When Copying or printing the paper does not feed
open the front cover pull out the cartridge and you see paper feed roller it is rubber. Clean paper feed roller with cloth and water or alcohol.
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
NAME OF TONER AND HOW TO REFILL
Samsung Black Toner Cartridge for SCX-4521F Part #: SCX-4521D3 samsung_scx4521d3.jpg
Its price: $76.99 You just pull outward the old print unit and replace it with the new !
Good Luck!
Dec 07, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F no categories error
Sorry venkates1233, it must be "No Cartridge Error" and not "No Categories Error." Now the fix is simple. Here it is: menu # 1934 display ready tech, press left arrow key and then enter twice.
Hope this will help. If you need any more assistance, don't hesitate to come back to us. Else, if the problem is solved, please DO ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 06, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How to operate and fix up the SCX 4521F
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
Works for SCX-4521F
Jul 02, 2010 | Samsung SCX-4828FN All-In-One Laser...
On receive of a fax it goes directly into memory without printing it??? SAMSUNG SCX-4521F
This may be due to paper jam,toner cartridge is about to finish.
These are the possible issues. Even after changing the cartridge if the same thing persists let us know.
Rafique
Jun 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F "no cartridge error"
In the back of the printer, after you take out the back side, there is a contact with two wire: black and red. That switch is presed by the cartridge. Or you should push more the cartridge into the printer.
May 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung LaserJet prints completely black pages
We had the same problem with our SCX but we replaced the Part #: SCX-4521D3 toner/drum and it worked fine after that. We replaced the starter cartridge with a 3000 print capacity cartridge.
Nov 20, 2006 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
646 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
