Microwave Ovens Logo
Question about Sharp Microwave Ovens
Microwave owen SHARP Model R9H20 Digital START button is not working. Need Workshop address in Dammam or Al-Khobar, Saudi Arabia including phone numbers to fix the problem.
Posted by ansarirw on
Anonymous
    New Friend:
R-9H20 (W) sharp microwave oven- the turn plate does not work kindly let me know what needs to be done. i need help. Kindly e-mail me .
[email protected]
Zaffar Iqbal
Posted on May 17, 2011
  • Khalid Ahmed
    Khalid Ahmed Oct 10, 2022
    Check the motor of the plate first, after disconnect its wiring clip supply the power directly if it works than it means the fault is somewhere in its supply wiring check that out if you find clear than go to the board if you are not professional do not attempt any try take your unit to authorized personal to fix the fault.
Start button does not work
If this is a Sharp R1500-series microwave (you didn't mention the model number but posted under that) then the most likely problems are:
- broken Start button see here
- bad door switch see here
- bad keypad or other problem see here
The service manual is here.
Sharp R21LTF not heating at all what should i look for
place a cup of water inside
program the owen for 1 min
remove the cup when done
check temp.
if hot, it works
if not, repair appliance
Digital read out quit working
We'd be happy to help you with free assistance - including part numbers, part sources, and service info - if you'll post a new help request to FixYa including the following:
  • brand
  • full model number
  • detailed symptoms
Pressed the "start" button and heard a pop behind
  • brand
  • full model number
  • detailed symptoms
I have a SHARP MICROWAVE oven SL - R-950B / R-954B. The Start button has stopped working recently and so the oven needs repair. Please send mt the address and phone number of the SHARP SERVICE CENTER in...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
The microwave oven start button does not work. If
You probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If it's not the switch or mount, you may need to adjust the door alignment.
If you still need help, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and requote your symptoms, as you posted previously.
HV CAPACITOR FOR SHARP MICROWAVE
Sharp may not sell you this spare part as it is a high voltage saftey part. You would have to take the oven to a Sharp dealer to have it fitted. However, CPC Farnell in the UK may supply, but be careful.
SHARP MICROWAVE R9H20 STOCKED FOR LONG
if the problem is tempermental then is sounde like you may have a failing interlock switch. this is a series of switches that are activated then the door closes. there are normally 3 and you would be looking for/ replacing the middle the Primary interlock...
Hope that helps
2helpful
2answers
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Top Sharp Microwave Ovens Experts
Jaime Hernandez
nu267
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
