Open google chrome
to the right of the address bar is a wrench icon, click on it.
almost at the bottom of the list it says options, click it
click on the tab that says " under the hood "
next click the button that says change proxy settings
in the next box that pops up, click on "never dial a connection"
next click on the LAN button
next ensure that all check boxes are clear, with no checkmarks in them
click ok
then click ok again
that should bring you back to the google chrome options box
click close
close out chrome
wiat about 10 to 15 seconds to allow for chrome to recognize the new settings
reopen chrome and you should be able to use it just fine
Open Google chrome >>To the right of the address bar at the
end is a wrench type icon click on it >>Almost at the bottom of
the list it says options click it >> click on the tab that says
"under the hood" >> next click the button that Change proxy
settings >> in the next box that pops up click on "never dial a
connection" >> next click on the LAN button >> next ensure
that all check boxes are clear, with no check marks in them click OK
>> then click OK again that should bring you back to the Google
chrome options box >> click close
Then close out chrome now
wait about 10 to 15 seconds to allow for chrome to recognize the new
settings >> Reopen chrome and you should be able to use it just
fine
SOURCE: Error 130 (net::ERR_PROXY_CONNECTION_FAILED):
Do you normally use a Proxy??? If not, then yes, it's most likely a
virus that sets proxy settings, directing all your network traffic
through the hacker's proxy. There, they capture all your internet
traffic including login IDs and passwords.
If you have no idea how long this has been going on, then they have all
your information already. Hacker proxies get shut down fairly quickly,
hence the error you are seeing now. However, the damage may be done
already.
Do a full virus scan, then go to all your online sites and change all the passwords - soon!
SOURCE: Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server
The error that you get indicates more of a proxy problem than a virus problem. If you are behind a proxy, you have to have this added to your Chrome shortcut, in the Target field after the location of Chrome: --proxy-server="proxy:port" where proxy is the address of your proxy and the port is the port number.
If you think there's a virus, follow instructions from here to clean your computer from viruses http://www.fixya.com/support/r7263144-clean_computer_from_viruses
Once you cleaned up your PC, if your copy of Chrome is still corrupt, or it's not working, try to remove it and install it again. Here's a link to the download page http://www.google.com/chrome
SOURCE: error 130 (net:err_proxy_connection_failed): proxy server
Hello i hope u 'll be fine.... thanks for using fixya.
Follow these steps
Open Google chrome >>To the right of the address bar at the end is a wrench type icon click on it >>Almost at the bottom of the list it says options click it >> click on the tab that says "under the hood" >> next click the button that Change proxy settings >> in the next box that pops up click on "never dial a connection" >> next click on the LAN button >> next ensure that all check boxes are clear, with no check marks in them click OK >> then click OK again that should bring you back to the Google chrome options box >> click close
Then close out chrome now wait about 10 to 15 seconds to allow for chrome to recognize the new settings >> Reopen chrome and you should be able to use it just fine
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Hello i hope u will be fine, thanks for using fixya.
Follow these steps
See my this Solution (Same as yours), 14 people thought it was helpful for them
See my TIP & TRICK foe this problem
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
