Question about Philips 60PP9401 60" Rear Projection Television
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
  • Philips Master
  • 8,457 Answers
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Dec 18, 2010
6ya staff
SOURCE:
Tv works but picture color is off and its kinda dark looking there is no duel image so i know the color tubes are ok but there is a problem it almost looks like someone took a magnet to it
You have two problems, you have a convergence problem, the convergence board needs repair, and the other problem is the coolant needs change in the guns, (CRT's) and you are looking at 500 on repairs, you would be better off getting a new LCD.
Mar 02, 2011 | Philips 43P8341 43" Rear Projection...
Image too big
You have two possibilities; either buy the original remote or look up the code for 'universal' remote for that set here:
Remotes
If you can't find the code set for the remote & TV you have, look for a code set for one of the following brand names:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
These are all made and marketed by Funai.
Nov 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
One of my colors are not registering with the others.
you will need to get convergence done to correct the color alignment and the warped look , those are the exact signs of the convergence IC's failing
will you be trying to do the repair yourself or will you be needing to call an electronic repair shop?
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Lost remote / convergance problem
u can not set the convergence without the remote control just look on the web they are between 30 and 60.00 dollars
Oct 07, 2008 | Philips 55PP9401 55" Rear Projection...
Mitsubishi VS-50501A convergence problem
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Philips 60PP9401 60" Rear Projection Television Logo
162 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
