Question about LG 42PG20 42 in. Plasma HDTV
How do i switch my lg 42pg20-ua to digital audio outpu
Posted by aaronbox on
Paul Pope
  • 592 Answers
You shouldn't need to switch anything, you do however need an audio reciever with a digital audio in jack, that's all connect the d.a.o. to the stereo in the right jack, and you should be good to go.
Posted on Dec 18, 2010
Convert 42pg20-ua main board to 50pg20-ua
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 27, 2014 | LG Televison & Video
Lg 42PG20 possible to work on a 220 volts?
The correct answer is "it depends on the power supply board used in it".
If you click on the picture at
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
and look at the lower left corner of the board you will see
100v-240V
printed in the lower left corner.
That board used in 42PG20 will definitely work on 220V.
Your TV may have a different board inside though.
DO not assume...verify.
Hope this helps!
Jun 29, 2014 | LG 42PG20 42 in. Plasma HDTV
Won't turn on for several tries
The most common reason for this behavior are worn out / failed electrolytic capacitors on the power board.
Those are easy to identify as they are usually bulged and easy to replace. We recommend to do it yourself and if you don't want to then find someone local, bring them the board and have them do it for a coffee or $20 at most (including parts).
If the problem is more complex you can use this:
We've also seen the same caused by a problem on the main board, but that is a remote second possibility. When it is, it's probably best to just get a replacement main board.
Sep 01, 2013 | LG 42PG20 42 in. Plasma HDTV
Orange bars flashing around the screen
This is a link for repairing the power supply board of a LG 42PG20, which also contains a link to an article on how to test the board's functionality, which is actually fairly simple:
May 16, 2013 | LG 42PG20 42 in. Plasma HDTV
I have a LG 42 inch plasma that turned off and doesnt want to turn back on. im thinking is the sensor is there anyone that can help out with this problem?
If you can turn it on with the button on the unit itself then it may be the IR sensor, but if you can't turn it on then it is very unlikely the sensor.
The power supply board of the 42PG20-UA is a known source of exactly this problem, although definitely not the only one that could possibly cause it.
Below is a link for a repair of the board, but the listing also contains a link to an article on how to test the power supply board alone, which is pretty useful before spending time and money sending it for repair. If anything you can rule one board out:
Nov 17, 2012 | LG 42PG20 42 in. Plasma HDTV
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
42PG20 42 in. HDTV Plasma TV: i have an lg plasma tv - 42pg20 when i turn o...
There are several known issues that can cause that.
The top candidate is the main board, the next is the Y-Main board.
Here's a link for repairing the power supply board of LG 42PG20, which also contains a link to how to test your own board to see if it is good or not:
Hope this helps!
May 17, 2010 | LG 42PG20 42 in. Plasma HDTV
LG 42PG20 42 in. Plasma HDTV Logo
160 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
