Question about Casio G-Shock Tough Solar Watch with Databank. : G 2800B 1VCR
My 2800 casio solar tough battery died. I put it in the sun it restarted but to the year 2000. how to adjust to present time
Posted by robert_ma424 on
5 Related Answers
Anonymous
SOURCE: How to adjust the band on a GW800D Tough Solar
By finding a spring loaded rod in the clasp (that is in the set of three holes in the clasp) moving it to the last position. However it was still loose, so by finding the spring loaded rods that hold the links of the band together, pushing them down in the direction of the arrows and removing enough links to fit.
Posted on Aug 30, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: My Casio tough solar watch refuses to charge. it
Your CASIO needs CAPACITOR replacement. Capacitor is the cell accumulating energy from any source of light. Go to your closest watch repair shop and ask to fix it. You do not need to visit any particular CASIO dealer. All capacitors/batteries can be exchanged at any watch repair shop. Rate me, plz.
Posted on Feb 05, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Casio tough solar databank Model DB-E30-1AV
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Casio watch manuals. Rate me, plz.
Posted on Feb 23, 2010
David Tolond
  • 2501 Answers
SOURCE: I have lost my instructions manual for my CASIO
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Jun 22, 2010
David Tolond
  • 2501 Answers
SOURCE: how to set the time on a casio tough solar?
You can get instructions from the Casio web site.
watches;
Accept terms
Posted on May 25, 2011
CHANGE TIME AT CASIO TOUGH SOLAR
Today my 6-year old Waveceptor has adjusted itself to daylight Savings time without my intervention. I was agreeably surprised. For all the years I have had the watch, I kept the module manual by my side just for the two times a year I have to adjust the time.
All this to tell you that you imperatively have to read the module's manual. If you do not have it visit the Casio Worldwide web site and download it. You need the module number. You will find it on the back of the watch. It is a 4-digit number inside a rectangle.
Apr 01, 2013 | Casio watch Casio Tough Solar Mens...
How to set the time on a casio tough solar?
watches;
Accept terms
May 24, 2011 | Casio Tough Solar Watch MTP1227
The word "LOW" always appearing
The word LOW means that the solar battery charger is not charging. This could be a defective charger or you're not out in the sun long enough to keep it charged.
Feb 06, 2011 | Casio Protrek Triple Sensor Tough Solar...
Protrek casio watche just stoped working
Is it SOLAR?
I have a Casio Pathfinder, SOLAR, ATOMIC! They have a permanent battery!!!
It must be exposed to the sun occasionally to charge. If yours has nothing on the display, try putting it out in the sun for a day. Put it in a window, sitting on a window sill. Depending on how little charge it has, it may take as long as three days to charge.
Otherwise, the alternative is calling Casio, getting an RMA and sending it to them for a battery replacement.
Aug 03, 2010 | Watches
I have lost my instructions manual for my CASIO G-2800-1 TOUGH SOLAR watch
watches;
Accept terms
Jun 22, 2010 | Casio G-Shock Tough Solar Watch with...
My Casio tough solar watch refuses to charge. it is flashing chg only but will not charge with sun light. what should i do.
Feb 05, 2010 | Casio WVA105HDA Wave Ceptor watch
Is the battery on the G-Shock MT-G recharge either by motion or sun light?
As you will see from the extract from the web site, these watches are solar powered.
" Tough Solar Power
  • Shock Resistant
  • 200M Water Resistant
  • 29 times zones (48 cities), city code display, daylight saving on/off
  • 4 Daily Alarms and 1 snooze alarm
  • Countdown Timer
    Measuring unit: 1 second
    Countdown range: 1 second to 60 minutes
    Other: Auto Repeat
  • 1/100 second stopwatch
    Measuring capacity: 23:59’59.99”
    Measuring modes: Elapsed time, split time, 1st-2nd place times
  • Auto Calendar (pre-programmed until the year 2099)
    12/24 Hour Formats
  • Accuracy: +/-15 seconds per month (with no signal calibration)
  • Storage Battery: CTL1025
  • Battery Power Indicator
  • Power Saving Function
  • Approx. battery life: 6 months on full charge (without further exposure to light)
    Module 5055"
Feb 03, 2010 | Watches
Casio G-Shock Tough Solar Watch with Databank. : G 2800B 1VCR Logo
282 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
