Question about Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
I need an owners manual for the FW 15 - Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
Posted by curtis10566 on
gklohn
    New Friend:
  • 94 Answers
GO TO E-BAY.
Posted on Dec 22, 2010
I need the owners manual so I can program the micro genie. I lost mine 15 years ago
Hi Dan, the link below is a web page with a few different model micro genies.... I hope you find what you're looking for....CHEERS..
micro genie Google Search
Apr 03, 2016 | Music
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
Need an operator's manual for yamaha electone el-15
You can find it here
http://www2.yamaha.co.jp/manual/pdf/emi/english/ele/EL15E.PDF
Mar 12, 2013 | Yamaha Music
I get a distorted sound from my speakers throug a Phonic Helix Board. It is connected on a PC through Fire Wire. The distortion is also there while using microphones or other inputs (CD-players etc.). It...
Hallo landgenoot ;)
It seems it is a power supply problem; distorted sound, no meters, solo buttons not working, headphones low level and distorted. One of the power supply voltages might be too low or even missing. The Helix series mixers use mainly 4 supply voltages: + 15 V and - 15 V for the analog part (audio), + 5 V for the DSP and logic and +48 V only for the phantom power. If for example the + or - 15 V is too low, clipping of the positive or negative parts of the waveform (dependng on which voltage is too low) will occur. If possible, first measure the voltages coming out of the power supply. You could use a metal part of a jack as ground reference.
For the FireWire board an extra voltage supplied by the switched PSU is used. It is specified as +12,2 V, but I measured 14 V. This voltage is lowered to + 5 V by a resistor on the FW board and a 7805 regulator. (Not very efficient!) But as far as I can see, the FW voltage is not the problem here. I have some service documentation of the Helix series mixers (12, 17 and 24, so if you need more you can conatct me: frankdevries [at] versatel.nl.
Groeten, Frank.
Mar 18, 2011 | Phonic Helix18fw 18 Channel Mixer with...
Don't need a repair. I need a manual. know where I
Line 6 has the manuals on their site.
The Spider III 15 is in two parts: part 1 and part 2
The first is the manual, the second is the sample settings.
Both are PDF files.
Jan 20, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Need owner's manual for Baldwin Cinema II organ
I have the original technical data for it, as if you wanted to build one yourself from scratch, but no owners manual. Did you ever find an owner's manual? Also, I have the organ itself.
Oct 07, 2009 | Music
Manuals for Concert Piano Korg C-15
I have a Korg Concert Piano (C-15S) which was working perfectly till about two months ago. I have been on vacation for two months, had left the piano unplugged from the electric supply point, but on re-connecting now, I get no sound from it. Is there a reset button (or other device) that I may have to use? Appreciate your advice.
Thank you,
L. Paul
Apr 03, 2009 | Yamaha Full-Size Keyboard
Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker Logo
120 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
