Acer (KV.16X04.007) DVD Drive Logo
Question about Acer (KV.16X04.007) DVD Drive
I have just bought Acer Aspire 5742 and included is the Super Multi DL Drive. 1. I am unable to fit in my ordinary CDs and DVDs, so does this mean that I have to buy special CDs and DVDs in order to use this drive? 2. I need to backup the laptop before I start using it, so what type of CDs and DVDs do I need to buy? 3. How will I be able to use/convert my current CDs and DVDs on my new laptop? Thanks. Ginny
Posted by shah458 on
Brian Sullivan
  • Acer Master
  • 27,725 Answers
Before making any changes or commitments to buy new cd/dvd
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 17, 2010
Acer aspire 5742z dvd drive not recognising cds
carnt get my dvd rewriter to work since i bought the lap top
Is the 'DVD-Super Multi DL Drive' on the Acer 5742 Aspire basically a DVD rewriter, or does it just play DVD's?
This Super-Multi Drive will write to dual layer DVDs (DVD+R DL or DVD-R DL) at a 4x speed. The full specs of the Acer 5742 are available here: http://support.acer.com/acerpanam/notebook/2010/Acer/Aspire/Aspire5742/Aspire5742sp2.shtml .
You should be able to place a dual layer dvd in the drive and have it recognized. Windows may ask you if you want to format the disc.
I hope this helps.
1helpful
3answers
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
2answers
I want to know how to make copies of DVDs and audio CDs using acer aspire 5742 laptop
Download and install Nero Burning Rom program, open it, set in the up window the option CD/DVD, get to preferite, copy CD or copy DVD option, depends by what you need, set the speed 4x for DVD or 8x for CD for have a good copy quality, insert the original disk, it will copy it, then insert the new disk to burn.
1helpful
Why won't my CDs or DVDs fit into the DVD drive of my Acer Aspire 5742-7438 laptop? The piece of plastic in the centre of the drive doesn't fit through the hole in the CDs or DVDs.
A super simple answer would be to take them out of the square case but I think it may be more difficult than that. Most cd/dvd drives have small ball bearings that work like detents and hold the disk in place to keep it from coming off. you have to press down firmly (10-18 inch/lbs of force) to get the disk to stay.
Good luck
1helpful
MAY U PLZ ASSIST ME WITH MY ACER LAPTOP ASPIRE 4330 THE DRIVE IS UNABLE TO WRITE ALL THE DVDS BUT IT IS ABLE TO READ DVDS THE ONLY PROBLEM IS BURNING DVDS. HOW CAN I ENHENCE MY DVD/CD-RW COMBO TO WRITE THE...
No Sir, Acer Aspire 4330 comes with different Optical Media Loadings, ( You can see a pdf file here )
Like;
  • DVD/CD-RW combo drive
  • 8X DVD-Super Multi double-layer drive.
But you have the first one, The Combo drive not the super so you can READ both CD's DVD's but can write only CD's.
Hope this removes your dilemma.
If helpful, kindly do Rate!
2answers
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
1helpful
2answers
Brand new acer,spindle is too large on multi drive for cds or dvds
There are three little spring loaded things that you have to push together to get the DVD or CD to fit, I had the same problem
Steve Sweetleaf
Steve Sweetleaf
shadow
