SOURCE: RGN ERROR
I found A great website on only Cyberhome DVD problems and answers hope this helps. http://forum.cyberhome-help.de/viewforum.php?f=4&sid=a36c52c7bf9d531a54b649a1dcf1f02e
SOURCE: DVD disics useable in CH-DVD 300
TRY MEMOREX BRAND THEY ARE VERY COMPATABLE with most players
SOURCE: No color picture on any DVD played
Make sure the scart lead in pushed in fully and none of the pins are bent!!
SOURCE: Cyberhome 300 not stuck on main blue Cyberhome screen
It may not be able to read the DVD because the laser is dirty. First try to reset the system ( with no disc inserted, open then close the disc tray and hold the stop switch on the UNIT NOT THE REMOTE for six seconds). Then with the disc tray open using a can of "AIR DUSTER" - dry air in an aerosol can, insert the can nozzle into the disc tray cavity and spray away. That may blow off any dust on your laser eye. Try it again and if it still wont work,unplug the unit and remove the six small Philips screws that hold the cover on( it pivots up and off from under a lip in the front panel), plug it back in and open the disc tray exposing the laser and clean the lenses with Isopropyl alcohol and a q-tip. Do this GENTLY you don;t want to disturb the laser alignment. Dry with another Q-tip or the Airduster and re-assemble. Note well the unit will be POWERED with the cover off so BE CAREFUL. Just did this with mine and it now works like a charm again.
SOURCE: I have a Cyberhome CH-DVD 300 DVD Player &
Toss this junk to the garbage can, this is how I solved my frustrations with my two units.
