Question about JVC AV-32120 32" TV
I do not have a remote control with my dvd player. How do I tune in my dvd player to my jvc tv remote? I can play dvd's but I cannot use the arrows to select options. thank you
Posted by mcdowall_m on
Chi Chu
  • JVC Master
  • 8,457 Answers
U can't not tune tv and DVD player together.Each have own signal frequencies.Try website like Remotes.com to buy an original or very close to the original remote.
Posted on Dec 17, 2010
I need a new remote
John, Check the attached links for replacement remote for JVC, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Replacement Remote Controls for TVs Stereos DVD Players More
JVC Store Remote Control Search
JVC TV Remote Controls JVC Replacement Remotes for TV DVD Home Theater...
Remote Controls JVC Remote Controls
Jun 15, 2016 | JVC XL-SV22 CD Player
I would like to program an older Samsung tv to my JVC LP21036-038 Remote I need the codes?
Unfortunately, the JVC LP21036-038 remote can only control JVC devices. It doesn't have any adjustable codes. You can choose between 3 codes (A, B, and C) so that using 3 JVC video devices doesn't result in conflicts. This remote came with the JVC HR-XVC14BU among other devices. The manual for the VCR/DVD player is available from JVC support. The direct link to the manual is http://resources.jvc.com/Resources/00/00/90/LPT1148-001A.pdf . See page 17 of the manual for the details.
I'd recommend you get a cheap universal remote to control the Samsung TV and the JVC vcr/dvd player.
I wish that I had better news for you.
Sep 13, 2014 | JVC Lp21036-038 Remote Control
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
Can't get my new DVD/VCR to work.
I read the instruction manual one more time. It said to tune my TV to Video and voila, the VCR worked. All JVC VCR's seem to need the tv tuned to Video to play back. I had an older JVC VCR and I had to do the same thing with it.
Thanks anyway.
Jan 18, 2010 | JVC Televison & Video
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Nov 16, 2007 | Televison & Video
JVC DVD player problem
You have set the DVD to progressive output for your big tv. The little one will not accept this. Your manual will tell you how to reset it. The remote may be needed. Reconnect it to the big tv and check the menus.
Sep 01, 2007 | JVC XV-N422S DVD Player
JVC AV-32120 32" TV Logo
Top JVC Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
