Hi
If the fan is working then most likely it is the heating element gone bad.
You can check this if you have a multimeter or continuity tester.
Replacing the element is not too difficult, you have to get the back off, disconnect 2 wires, undo the fixing screws then fit the new one.
Don't forget to turn the power off first tho'.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
