Question about DeLonghi RT400 Retro 4-Slice Toaster
How to take DeLonghi RT400 apart? Thanks - DeLonghi RT400 Retro 4-Slice Toaster
Posted by letourneau_j on
I have a Delonghi room Unit PAC CN120E that stop cooling I have had it 5 years,
Take it apart take it outside and wash both coils with a water hose.
Oct 03, 2015 | DeLonghi Heating & Cooling
How do you remove back of delonghi pac cn120e ac
Remove screw s from back around unit and the back tilts and lifts off.. not easily i might add. I have a question posted as to where do plug wires attach to inside unit. Replacing plugc and not sure where black and white connect to. Can you help me..no one seems to have had theirs apart. I can send a pic of screws location if you need. if you can msg me back . Thanks ahead
May 13, 2015 | DeLonghi Heating & Cooling
I am looking for a operators manual for a AHWI RT 400 mulcher.
That's not a mulcher. It's a toaster. You need more than a manual.
Sep 23, 2013 | DeLonghi RT400 Retro 4-Slice Toaster
4 slice toaster when pressed down to start toaster they won't stay down.(either side) Yes I have it plugged in
Try cleaning the bread crumbs out of it. If you get enough piled up under the latch mechanism, you can't push it down far enough to engage it.
You may be able to do an adequate job by opening the bottom cover - most toasters are made so it's easily removed for this very purpose. If not, you'll need to pull off the knobs and remove screws so you can take off the top cover. Be careful not to touch the heater wires with any tools - after they've been used a while they become rather brittle and break easily, and even a scratch can cause them to erode and fail. I assume you know to unplug the toaster before working on it.
Jan 06, 2011 | DeLonghi RT400 Retro 4-Slice Toaster
DeLonghi RT400 Retro 4-Slice Toaster Logo
Top DeLonghi Kitchen Appliances - Others Experts
Paul Bade
Gerry Harvey
Gerry Harvey
ADMIN Canada
ADMIN Canada
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
