Canon LASER SHOT LBP-2900 Printer Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A paper has struck in printer so its not printing how to remove the paper
Anonymous
Level 2:
Scholar:
  • Expert 79 Answers
  • Posted on Dec 17, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
79
Questions
0
Helped
29686
Points
274
1) Open the top cover
2) Remove the toner cartridge
3) Remove any paper from the multipurpose tray
4) If you can see the LEADING EDGE of the jammed paper slowly pull it out.
This may be easiest from either the multipurpose tray side or from under the toner cartridge
5) If you can see the TRAIL EDGE of the jammed paper slowly push it through the printer until it comes out
Does not print, paper is struck off, shows red light
Struck off , needs your explanation on Struck off
2helpful
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Print head is stuck to the far right of the printer I have had problems in the past with the head cleaner popping up and stopping the print head from going home but now it has I think come loose and...
Hello and Welcome to FixYa!
Sir, In Epson Printers if print head is struck and it don't move then it may be because of several reasons.Mostly problem of print head struck is because of Paper Jam, actually their may be small bit paper jam in side the printer head,There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and it struck the Print Head.Open printer cover and check to make sure no paper or foreign objects obstructing the printer feederIf you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.It will clear the printer jam and it may allow you to move print head.
If problem still exist then it may be due to dirty or clogged print head which hinder a regular flow of ink from the ink cartridge to paper. The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head and print head struck because of it. This problem can be solved if you clean the print head with software, There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printers software that will actually clean your printer for you. You can use them to clean it, After cleaning it may allow you to move the print head.If the built-in cleaning functions don't seem to do the job then There are a few ways to clean your print head manually. Its technical because you need to open the Printer, First remove the ink cartridge from the print head and take the print head out of your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it's really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle,This should get rid of any dried ink that was loosened during the soaking. Be careful, especially if you use isopropyl alcohol to clean your print heads, Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out.This process surely helps you but its highly technical so i recommend if your product is in warranty or out of warranty.If your product is in warranty, Simply contact to Epson Service Center or from where you purchased it and claim the warranty. Your problem will be solvedI hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
My printer did not print and the 2 light are alternate blinking?
check if any paper are struck in the cartridge remove the cartridge then check it and re insert
check the printer states in control panel
There has struck in second paper when I printing more than one pages. Help me
Sometimes the paper, like money, will stick when printing. It's just the paper.
You may need to feed your printer the paper one page at at time until you get some new paper. The thinner the paper stock, the more likely it will stick to each other when printing.
Try getting some thicker paper (paper weight) when returning to the store.
Hi i have a problem during printing is the paper is strucking in the middle of during printing processes the printer modle number is Dell 1710
Hi, the printer manual or the printer itself would have instructions on how to remove paper jams. Also loosen the guides alongside the paper feed a bit to ensure it is not holding onto the paper sides too tightly as this will continue to cause jams.
HP All in one 7110 powers up fine, printer roller is not working
Remove the rear axis door and then try to clean the rollers with a soft cotton cloth and then try to print again. The rollers might not work if there is any dust and pieces paper got struck in the rollers.
old marine
old marine
ZJ Limited
ZJ Limited
