Kingston 2GB Secure Digital Memory Card Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i use my memory card to downloaded saved files? (my resume) it's a microsd ,2gb
K W
Level 3:
Guru:
  • Master 509 Answers
  • Posted on Dec 17, 2010
K W
Master
Level 3:
Guru:
Answers
509
Questions
7
Helped
215968
Points
1369
Yes. You can save any type of files from your computer to the card. Make sure to create a folder on the card to put the files in first.
I'm using a 2gb memory card.but i can save data only upto 1.4gb.if i attempt to save or download more than 1.4gb it says "unable to save,it is a fat file".what should i do.
Hello=)
Your memory card is probably using the FAT32 filesystem. FAT32 has limits to how big of a file you can copy over to it. What you need to do is i reformat it.
Follow these steps: Backup anything important->Hit "My Computer"->Right click on the usb pen drive->Select "Format"->Under the "File System"-tab select "NTFS"->Hit quick format->Click start.
Done. :)
Hope this helps!
2answers
SanDisk 2GB MicroSD Memory Card recovering data software
Since I was facing the problem when I connected my memory card to the system and accidentally deleted my photos in memory card and came across the recovery software to recover data from memory card and here is download link
11helpful
2answers
I have 2gb sandisk memory card i dnt giving password.but appear password plz giving common password.
Hello Ayca,
To Unlock the SanDisk 2GB microSD Memory Card password you will require the Nokia 2690 or Nokia 2700 Classic phone.
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock the memory card password.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
3helpful
Saved pictures from my phone to the memory card, its a 2gb micro sandisk. When I plug the card into the computer it shows the files were saved there but every time I open the file it says the file is...
Maybe your memory card is somehow corrupted? Unfortunately you would have to format your memory card and lose your data.You can however try using a program like recuva to try and recover the files.
1helpful
How do i use my pny 2GB microSD Memory Card in my phone?
Slot the MicroSD memory card into your phone, power on the phone. Scroll the phone menu to navigate to the memory card. You can also use the phone setting to set the phone to use the memory card to save pictures taken from the phone, Music, Videos or even your personal documents
12helpful
2answers
I forgot my password of my 2gb microsd memory
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • No you will see the password.
Please rate this solution, if it works
Rnj VinodKumar
I CAN`T PUT MUSIC IN IT
Make sure that the microSD card is formatted. You may reformat the memory card using your phone and then try saving some music.
If that will not do any help, try using another microSD card to see if the card is defective.
Have a great day!
Memory card for my nokia
According to the Nokia site the 6085 series uses a MicroSD card,Up to 2gb is supported..I think.
Not sure of your location but this nokia site for Nokia 6085 Memory cards has them
( you may need to enter your location and browse from there ! )
I'd try searching ebay for --> MicroSD+memory+card <--
like I said before I know that your 6085 will support up to 2gb sized cards,So stick to cards up to 2gb in size !!
I use a MicroSD-->SD adapter card. The MicroSd card slides into the back of the SDcard. Then I use a SDcard-->USB adapter to be able to read and write data on the MicroSD card.
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
