The correct information you can find on the manual. Please check out for it on https://epartsmanuals.com/
I would look on u tube
SOURCE: Manual needed for JD 3 bottom plow w 3 point hitch
The first thing to do is get all the information you can off your plow. Like: serial number, model number and any info on any tags you find then go to the John Deere web site. Go to the plows section and you should find everything you need. They do have parts lists and manuals on the site. But it may be harder to find parts without at least a model. But they do have help areas you can try. Try there and if no luck try to give me all the info you can about what you are looking for and I'll do some research for you.
SOURCE: How to see if a used snow plow blade will fit my craftsman tractr
Underneath the hood of your tractor is a silver sticker with the sears item number for the correct snowblade. If its a craftsman snowblade it should have a meteal label on it with its model number the 5 numbers after the period need to be the same with what was under your hood to make it the correct blade
SOURCE: I need a picture of asnow plow installation
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0603016.pdf
here is a craftsman 42 inch snow plow instruction sheet
SOURCE: riding mower snow plow
go to manuals online put in model number off the snow plow and it will show you the manual
SOURCE: I have a craftsman tractor model 917.276813
No, there is no place to prime the engine. But, I have one that doesn't like to start in cold weather also. I use a one second burst of starting fluid into the air cleaner. You can get starting fluid at any auto parts store here in the U.S. Gumout, Gunk, Heet are a few good brands.
Can you please add details in the comment box?
Manual for sale online for gravely 8122. Unsure if that will be of any use. May want to contact sellers online or snow plow vendors in your region.
https://www.amazon.com/Gravely-Garden-Tr...
