SansuiM1315 TV Logo
Question about SansuiM1315 TV
Hi, I have owned the Sansui TV SV2918 for almost seven years now when it recently on it's own while on, started switching itself 'off' then 'on', played for couple of seconds then ultimately couldn't switch on any longer except an idication that it is on. It started a couple of months ago, when in would show on the screen the three seconds time off without being programmed to do so, however I would just deactivate the time-off time ech that showed on the screen, until the recent mishaps. I tried to enquire from some 'expert' who highlighted a potential problem with some 'processor'. Initially I thought it could have been a fuse gone dead and I checked it but it seemed perfect, how do I solve the problem
Posted by Maxwell Moholi on
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Sansui SV2918 has no picture and audio only a blue screen
Have you tried the a / v inputs?? If they work,might be a bad tuner.If they don't work,then your symptom is no video-no audio=
power supply problem? Check all voltages....T.
Posted on Oct 25, 2007
Anonymous
  • 6 Answers
SOURCE: TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
Posted on Apr 08, 2008
Anonymous
SOURCE: sansui tv sv2918
Sweetch on thr tv just one vertical line comming in center of ty screen
Posted on Jun 20, 2008
Bob Citizen
  • 520 Answers
SOURCE: Very poor service 6 months and tv is going out!
Turn off the text box function of the closed captioning.
Posted on Sep 06, 2008
Bob Citizen
  • 520 Answers
SOURCE: Sansui without remote
No. You will need the remote. Call the number on the set for an original. You could try your luck with a universal remote. Try a RCA brand. Good Luck!
Posted on Oct 22, 2008
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
1helpful
Tv not switching on Sansui SV2918, replaced faulty PTC and trans D2449 for lopty switching
all the transistors ,& capacitors i.e 47mfd 63v or100mfd 63v must be changed before u on the tv. if 300v is not coming to middle pin of d2449 then 4.7ohm resistor(fusible) may be gone
Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
2helpful
Hi I live in Kempton Park South Africa and my Sansui TV Model SV2918 does not swith on. The product is very good and I would like it to b repaired. Do you have suggested maintenance people that I coul
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
1helpful
2answers
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Top Sansui Televison & Video Experts
 Grubhead
Grubhead
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
