NF stands for, No Fill. This is caused by 1 of 2 problems. The first and simplest is to check the screens on the inlet valve by removing the fill hoses to the washer and looking with a flash light. There should be no rust, sand, or water deposit on them at all. If there is remove it and test the machine. If there is not you will need to replace the water inlet valve assembly. This part can be ordered at http://www.reliableparts.com/, by using your model number.
Please rate my solution if it was helpful to you.
Thanks, Repairman45
