Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony KDF60WF655 and have a yellow spot on the top left of my screen. Is this a symptom of a bad lamp? And which lamp model would i need?
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Dec 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
5616
Points
41
Email [email protected] / Please let them know your model number, serial number, symptom or question/concern and your contact information including... a phone number and they will get back in touch w/you
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 301 Answers
  • Posted on Dec 17, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
301
Questions
0
Helped
79247
Points
655
THAT COULD JUST BE A DUST SPOT INTERNAL TO THE OPTICAL ENGINE. THE LAMP CAN ONLY AFFECT BRIGHTNESS NOT ANYTHING TO DO WITH COLOR DISTORTIONS. IF IT NEEDS CLEANING I SUGGEST CALLING A SERVICEMAN
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
BLACK SCREEN WITH RED ON TOP RIGHT ON SONY WEGA TELEVISION
Optic Block failure. Lamp wont help you there unfortunately. The KDF60WF655 was a good TV back in its day. Don't waste your money on repair and return the lamp if you can.
3helpful
Replaced lamp from Sony in January. In the last month or so been noticing a large yellow spot in the middle of screen. My TV is a Grand Wega LD Projection TV Model No. KDFE42A10, Serial #9507132.
your optical block is failing. Sony has a program for replacing them if you want, or they will offer you a new TV. call this number 239-768-7604 and tell them what you TV's symptoms are and they will get you started
1helpful
I have a sony model kdf60wf655. i replaced my lamp nearly a year ago, but now i have black screen, no sound, and the lamp light is constantly flashing red. please advise how to fix.
Lamp light constantly blinking shows that lamp is dead/ broken. If any thing else like ballast supply etc become defective, standby light will start flashing in specific order.
Replace lamp and make sure to get Son original replacement lamp to solve the issue.
Thanks.
5helpful
I have a sony tv, model number KDF60WF655... i turn the tv on and it turns on for about 1 min then turns off, the green light flashes several times then turns itself on again. the process keeps repeating...
Replace lamp in tv as this symptom shows existing lamp is near to end of its working hours life span and need to be replaced.
Lamp replacement procedure is easy and would be written in user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
1helpful
Hundreds of Blue dots on model KDF60WF655 Grand Wega.
optical block about 900 unless you can get a good used one. thats a common problem with that model
Sony kdf60wf655 tv have sound but no picture after turning on for
Its symptom of weak lamp, please replace lamp. Lamp replacement procedure is written in user manual and always buy original Sony lamp for replacement.
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Sony kdf60wf655
sound like a lamp you can easily check this there is a door on the left side of the tv open it reach in thump on top finger in the loop squeeze and pull.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
