Mitsubishi WS-55809 55" Rear Projection Television Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there and error code 12 and if so what is it please and thank you.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 301 Answers
  • Posted on Dec 17, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
301
Questions
0
Helped
79292
Points
655
ERROR CODE 12 IS "NORMAL OPERATION" IF THAT IS THE CODE THAT THE TV IS GIVING YOU THEN IT THINKS THERE IS NOTHING WRONG WITH ITSELF. YOU HAVE TO CHECK FOR THE ERROR CODE ONLY AFTER THE TV FAILS. TRY TO POWER ON AND IF IT DOESN'T THEN CHECK ERROR CODE.
1helpful
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
2helpful
94/95 jeep 4 lt. Seem to have error code 12 followed by 55. Manual we have doesn't show 12 as an error code - any clues, please?
12 indicates that the battery has been disconnected recently. 55 shows the end of the code sequence.
Therefore, whatever problem you are having, it isn't generating a code.
Please can you tell me what error code 12 means and how to fix it or reset it on my Mitsubishi WS 65513 TV? Thank you!
seniomsed,
Error code 12 means there is a problem with the lamp system. This model has a known defect in the DM board and power supply board. Mitsubishi does not support it and has no spare boards. After market vendors do make repair kits. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which will help solve your problem.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
7helpful
F 12 whirlpool 6 th sense washing machine.
hello,
simple ,The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
thank you and thanks for using fixya.
4helpful
Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
2helpful
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Paper feed error on machine
I am going to assume that your exact error message is No Paper Fed. This is mentioned on page 12-3 in Chapter 12, Troubleshooting and routine maintenance, of the Users Manual.
Since you said that paper is in the unit, the most likely cause is a jam. See pages 12-5 through 12-8 of the Users Manual for instructions on clearing jams.
It is possible that the error message is a "false positive." Power down the unit for at least one minute, then power it up again.
If the aforementioned advice does not resolve the problem, the printer probably needs to be serviced. You can find authorized service centers within a certain radius of the ZIP code of your choice by following this procedure:
1. Visit http://www.brother-usa.com/Service/.
2. Select Fax/MFC (color) in the --Please select product group-- selector box.
3. Type the ZIP code of your choice (presumably your home ZIP code or work ZIP code) into the Zip Code: text box.
4. Click on the radio button for the desired radius from your specified ZIP code. (If you want to "walk" your unit into a repair center, click the 20 miles radio button.)
5. Click the Next button. A list of authorized service centers should appear.
2helpful
LENS ERROR
Dear Sirs
MY CAMARA GIVES ME A LENS ERROR M527 - 12 (7F80)
CAN YOU PLEASE HELP THANKS
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
