SOURCE: monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
SOURCE: My HP1906 Monitor is asleep ... How do I wake it up.
Hi...there,
Well, new could be defective too... You're probably got a busted backlight inverter problems... Send it back for repaired. Happy Holidays!
SOURCE: monitor goes to sleep and never wakes up
if you are on the desktop, right click and choose nvdia control panel and choose the nview display mode to use. select only use one display(single) maybe your input signal is in the wrong selection.just try it maybe it will help
SOURCE: AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
SOURCE: Monitor going to sleep
You most likely have a hardware failure.
Your video card or on-board video in the computer is probably dead.
