Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has the clearance it needs to function. The pilot stays lit, but the burner cuts out. It turns itself back on after about 4-5 minutes. It isn't heating the room, or anything else. Any ideas?
Posted by fourthandsim on
Anonymous
    New Friend:
Well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Posted on Jan 19, 2011
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
Ignition control failure
Try cleaning the flame sencor first , or it could be the snap dice shutting down there are two on there you could bridge them out one at atime and see if it stays on .
Nov 22, 2012 | Mr. Heater Natural Gas Garage Heater -...
I have a Dyna-Glo natural gas unvented roon heater that is wall mounted. The model is #GH-55(30,000 BTU). The pilot lights,but the main burner shuts off after 10-15 seconds with a fairly loud clunk. Do...
the pilot says on yes ? if not pilot could be blocked and need cleaning out or thermocouple needs changing if pilot is staying on then there could be a limit switch shutting off too soon , or burner needs cleaning
Jan 20, 2011 | Heating & Cooling
I have a RMI-70LP Dyna-Glo 18,000 btu unvented room heater. Can it be converted to natural gas?
These can be converted by changing the orface on the heater and also the regulator. Best to contact your gas company or Dyna Glo to obtain the correct orface for that particular heater.
Oct 08, 2009 | Dyna-Glo Heating & Cooling
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
239 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Michael Thomas
Michael Thomas
Jon Seaman
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
