Question about Sony BDVE770W Theater System
I just purchased a Sony BDV E770W home theatre system and there are 2 problems that I need help solving. I have a 30GB iPod Classic which I am trying to play through my home theatre system, but when I connect the iPod to the system using an Apple USB cable an error message reads: This iPod is not compatible with this system. Any reasoning to why I would be having this issue? My second problem is that our TV does not have either an HDMI or Digital Optical out jack on our TV, so as a result the Sony theatre is not supplying volume to our TV. We are using component cables at the moment on our Mitsubishi High Def. TV. Would you know if there is any other way i can connect my theatre to my TV so I would be able to get sound coming through the television? Your help would be greatly appreciated. Thank You
Anonymous
Hey there - did you ever get a solution to this problem? I'm having the exact same problem with my iPod Classic (60gb). I've tried using Sony's online tech support, but to no avail.
Posted on Jan 03, 2011
  • Anonymous Jan 03, 2011
    Well, here's an update - I just got online again with Sony Tech support, and currently they only support iPod Classics with 80 GB, 120 GB, or 160 GB. So, that's why yours (and mine) don't work.
I ha e a sony BDV-E770W Blu-ray disc home theater system and when you press the pwr on button it comes on and dispray says please wait flashes and doesn't do anything else. No sound, no menu show.
Sounds like corrupted firmware. Contact the authorized service center for Sony. or, visit this site, sony e-support. This kind of fault/s are not easly repairable by a user.
https://esupport.sony.com/US/p/model-home.pl?mdl=BDVE770W&LOC=3#/howtoTab
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 21, 2016 | Sony Audio Players & Recorders
Bdv e3100 region free
try this
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 1891 (this sets key 1 - the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 - the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 - the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 - the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 - the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Oct 16, 2013 | Sony BDV-E3100 5.1 Channel 3D Blu-ray Disc...
My home theatre unit bdv-L600 will not eject the DVD as it says it is locked
I think your best bet is to remove the top of the unit and see what has caused it to lock. Removing the CD once the top is off may fix your problem.
Nov 10, 2012 | Sony BDV-L600 3D Home Cinema System SONY1
How to unblock region code block of sony bdv-e770w?
It's already Region Free when purchased.
  • A+B+C Multi Zone Region Code Free Blu Ray Player DVD Region 123456 PAL/NTSC
  • PAL or MULTI-SYSTEM TV is required to watch PAL DVDs. If your TV was purchased in North America (NTSC) you will also need a Video Scaler Full HD 1080p.
    May 07, 2011 | Sony BDV-E770W 3D Blu-ray Theater System...
    I can't get tv to send sound to sound system
    Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
    Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
    Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
    The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
    DIRECTLY FROM THE USER MANUAL
    source from
    http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
    ? Connecting to Audio Receiver:
    Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
    AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
    METHOD A:
    Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
    OPTICAL OUT jacks.
    METHOD B:
    Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
    COAXIAL OUT jacks.
    Note: Above mentioned function is only available under HDTV (cable/air) mode.
    ? Connect all AC power sources, before turning on the power switch of the LCD TV or
    other connected equipment.
    ? Press the button on the remote to turn on the LCD TV."
    May 25, 2017 | Polaroid FLM-2632 Television
    PHILLIPS HTD 7001 IPOD DOCKING STATION
    I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
    May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
    2007 Audi A4 cabriolet / 30GB ipod compatibility
    your description goes around and around, what do you actually want to do what is the main problem?
    Apr 07, 2008 | Apple iPod MA446LL/A MP3 Player
    Open Questions:
    Sony BDVE770W Theater System Logo
    384 people viewed this question
    Top Sony Audio Players & Recorders Experts
    ThaMp3Doctor
    ThaMp3Doctor
    Muntejaya Ginting
    Muntejaya Ginting
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
