Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Need trippers for model 4001-00 - Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
  • Anonymous Dec 16, 2010
    price and where to purches
Jim Moody
    New Friend:
    Problem Solver:
  • 9 Answers
Posted on Nov 23, 2011
Anonymous
Paragon 4000 series timers use X2772 tripper
http://www.paragontimecontrols.com/parts_accessories.htm
Google search for X2772 Paragon tripper
Midnight electric stills sells them
http://midlightelectric.com/firex/acatalog/FIREXPARAGONROBERTSHAW_X2772.html
Email from paragon in Nov said that Paragon is no longer making timers and parts, except for defrost timers.
4000 series is not a defrost timer
To change over to Intermatic, buy 120Volt T101 timer or 120/240V GM40
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
GM40
http://www.intermatic.com/products/grasslin/auto%20voltage%20time%20swtiches/gm40/gm40av.aspx
T101
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
Posted on Dec 16, 2010
3 Related Answers
Anonymous
SOURCE: WE HAVE A PARAGON TIME CONTROL MODEL #4001-00,
http://waterheatertimer.org/Paragon-timers-and-manuals.html
I think the 4001-00 takes the X2772 tripper
If you google Paragon X2772 tripper, there are a few sellers charging from $9-16 for a pair of trippers as if they are made of gold
http://www.nextag.com/tripper-paragon-x2772/stores-html
Posted on Oct 21, 2010
Jim Moody
  • 9 Answers
SOURCE: I need a set of
http://www.patriot-supply.com/products/showitem.cfm/55426
IN STOCK AT PATRIOT SUPPLY!
Anonymous
SOURCE: I need the on tripper
Google search: X2772 tripper
Thank you for including model number.
Paragon is no longer making 4000 series timer or the X2272 tripper.
Some places might still carry the tripper.
Resources:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Replacement timer for 4001-00 is Intermatic T101 timer:
Crossover wiring from 4001-00 to T101:
Paragon terminal 1 connects to Intermatic terminal 1
Paragon terminal 2 connects to Intermatic terminal 2
Paragon terminal 3 connects to Intermatic terminal A
Resource:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 12, 2011
Intermatic troubleshooting
You need new 120V WG1570 clock motor
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
Order extra trippers too... motors and trippers are replaceable so timer can last 25+ years
http://waterheatertimer.org/Buy-T100-series-timers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 27, 2014 | Intermatic Hardware & Accessories
Where to purchase trippers for GE mechanical time switch model #15163?
This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f415602webg2.jpg
Jul 03, 2014 | General Electric GE 56941 24-Hour Outdoor...
Tripper parts for Model HB35R
1) Copy following links to identify product and trippers, available at Intermatic store:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#P1261
2) Add comment and describe what happens
Dec 16, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
I need trippers for an Intermatic Raintight Outdoor Timer model HB11R
1) Intermatic trippers: Buy Amazon or Intermatic store
Copy following link to identify tripper
2) Copy following link to identify Intermatic analog timers with replaceable trippers
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
3) Add comment and describe timer in detail, and color of tripper
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
Flippers not functioning
be sure that the trippers you are using are for this specific model if you purchased them seperately.
if they are for your model then make sure they are fully seated so that they are engaging the switch. if you are using trippers you have had a long time the remove one go to your local store where you can buy the low voltage power pack. they should have additional trippers to go with your model examine the new trippers to make sure yours look the same and are not worn or broken. if all appears good then you may have a problem with the switch that is engaged by the trippers and the unit may need to be replaced.
Feb 25, 2011 | Malibu ML200RTW - Low Voltage Power Pack...
I need to get some trippers for my paragon hot water heater timer i believe it is a 4004-20....any suggestions where i might can purchase them....thanks bill
4000 series Paragon timer uses X2772 tripper
To check your model:
Midnight electric sells X2772 tripper
That being said,
According to e-mail I got from Paragon last month, Paragon is no longer making timers or timer parts. Except for defrost timers. 4000 series is not a defrost timer.
This explains why some sellers of these trippers are asking $50 or more for $3 pair of trippers.
To change your timer to Intermatic.
Refer to Intermatic cross reference:
Dec 06, 2010 | Hardware & Accessories
Lost pcs.that turn on and off the little silver clips that screw onto the disc.where can i find replacements? the ones i found at the hardware store dont match tab is in a diffrent location. its the older...
If I understand correctly, you need tripper pins for a Paragon timer
At page bottom is a chart with model number and the tripper required
The two links above help you identify your timer model and identify the tripper.
After identifying tripper number, you have to do a google search for that tripper number
So, if you need more help, please answer back and we'll find the right timer and pin
If you have Intermatic timer, then you can buy pins at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Oct 21, 2010 | Paragon Hardware & Accessories
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
4,319 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
