Question about HP DeskJet F4280 All In One Printer InkJet
I bought my hp deskjet f4280 over 2years ago and i kept it without using it. It was brought today and i discovered that is not printing. The resume red button is blinking. Several test pages were sent to the printing but failed to either pick paper nor print
Posted by jeto2003 on
Paul Pope
  • 592 Answers
Well, i would guess that you are using the ink cartridges that came with it.
The ink actually has an expiration date like food, and more thab likely the ink has dried up. If the printer is reading the ink levels, is may count them as being empty.
Try getting new ink and see if that works, as that is most likely the cause of the fault.
Posted on Dec 16, 2010
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
I have a HP Deskjet D4160 , worked fine until today. resume light flashes, will not print my document
This is a step by step solution.
Please let me know if it fixes the issue.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00635074&prodTypeId=18972&prodSeriesId=501868
Mar 20, 2011 | HP Deskjet D4160 InkJet Photo Printer
My printer model is HP Deskjet F4288 All in one printer. Recently i ve brought new Color catridge and re filled Black and white catridge today but still it is showing not able to take print out.
OK, HP recommends that new HP cartridges be used rather than refilling. I've had better results with new cartridges that are name brand than trying to refill to save money.
Feb 04, 2011 | HP DeskJet F4280 All In One Printer InkJet
Replaced only black -- will it work without a new colored ink cartridge? Resume light keeps blinking.
hi both of your inks need to be installed with ink in if there is one with no ink like the color the printer will not work, you will have to wait until you have the color.
May 20, 2009 | HP DeskJet 648c InkJet Printer
Printer won't stop printing garbage
Try and re-install your printer drivers...first remove the drivers and delete the printer...then re-install.
Dec 03, 2008 | HP DeskJet 812c InkJet Printer
Hp deskjet d1430 not printing
If you double click on the print que, look at the status heading...what does it say? If it says printing and then windows gives you a "this document failed to print", then you probably have a driver issue. Delete the printer and re-install. If it says paused then right click on the job and clickon resume. You might also want to check in the printers and faxes folder, right click on the driver for the printer, see if an option is there that says resume printing, click it if it does. Also right click on driver and select properties, under the ports tab see if the correct port is selected. Best I can do without knowing more detail.
Larry
Dec 01, 2008 | HP Deskjet D1430 InkJet Printer
Just brought a hp deskjet all in one F4280,the software that came with it is for F4200 is this the wright software.
Software for F4200 series will fit all HP starting for F42..., including F4280. That is the right software.
Oct 22, 2008 | HP Office Equipment & Supplies
HP DESKJET 1280
I have the same problem. Yellow light now constant and will not print at all.
Oct 11, 2008 | HP DeskJet 1280 InkJet Printer
The power button keeps blinking and I can't shut the printer off . I was printing directions from mapquestand only one page and part of another page printed. I tried several times to print again but...
I fixed the problem. I guess I hit the hold button on my printer without realizing what I had done. That's why the printer would not shut off and it was kept in the active state. I just started hitting buttons and once I hit the resume button the printer started working again.
Thanks anyway.
Jul 07, 2008 | HP Office Equipment & Supplies
HP DeskJet F4280 All In One Printer InkJet Logo
108 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
