Epson Stylus C86 InkJet Printer Logo
A
Anonymous Posted on Dec 16, 2010
Two red lights flashing, but i can't figure out what's wrong
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Dec 16, 2010
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689363
Points
8444
According to the documentation for your printer.
Red two red lights flashing, but - probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Twin transvision 3 plus not working, what is the problem?
Could be about anything, your going to need some voltage readings to figure out what is wrong
I can't figure out what is wrong with my Hitachi CP-X605 projector.
The ballast (which provides power for the lamp) might have gone bad. Check the voltage its outputting with a digital multimeter.
Why does my camera have a red flashing light on the camera and no signal on the tv
Normally a flashing red light is a warning signal. Perhaps the camera does want to tell you, something is wrong? (Wrong connected, or wrong startup, wrong voltage? who knows?)
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
1helpful
3answers
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
What to do when your vectron wave is blinking red and green at the same time while charging.
When you attach the charger the wrong way round it will flash red and green. Turn it around and it will just flash red. Then when charged it will go orange.
1helpful
Iron will not heat up and the auto off red light keeps flashing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
