Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
My Bosch SHX46A02UC-23 dishwasher is continually letting in water from water supply, even when unit is turned off.
Mark MacDonald
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description, " dishwasher is continually letting in water from water supply, even when unit is turned off "... and to answer your question, the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve, not surprising for Bosch unfortunately**
This is what to look for..i.e.
As long as your model number is indeed correct, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fasteninMy Bosch SHX46A02UC-23 dishwasher is - 156e176.jpgce.
3) the feed tube to the machine aMy Bosch SHX46A02UC-23 dishwasher is - 5937279.jpgof the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Posted on Dec 16, 2010
Water comes into dishwasher cold. why???
Welcome to FixYa.
Have you insured the unit is connected to a hot water supply line ? The water will not heat until it start's to circulate and activates the "flow switch" in the Bosch dishwashers.
If it is connected to a hot water supply, try running the hot water at your sink taps before turning on the dishwasher. If you still do not have hot water, check your hot water heater or supply.
If it is indeed connected to a cold water supply it will work, just be prepared for very long wash cycles since the Bosch machines will heat the water at a rate of 2F per minute...it could take a long time to reach 155F.
Let me know what you find out and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
My bosch dishwasher is not producing hot water, all other functions are running normal .
THE WATER GOING INTO MACHINE IS NOT HOT. LET WATER RUN UNIT IT IS HOT THEN START THE MACHINE. HEATER ONLY FUNCTION IS TO MAINTAIN THE HEAT , IT DOES NOT GO FROM COLD TO EXTRA HOT
Feb 15, 2010 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Bosch Dishwasher SHE6AF06UC won't turn on
use a voltage tester to check your incomeing volts and amp`s
Oct 07, 2009 | Bosch 24 in. SHX46B05 Stainless Steel...
Bosch dishwasher continues to run (Model SHX46A02UC)
This is too common a problem with these units. I have written a guide to help folks out with it. Find it here.
Jul 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Continuious Filling.
seems like the inlet solenoid valve is stuck in the partly open position. This happens when tiny particles become entrapped inside the valve even though manufacturers attempt to prevent this by installing a screen at the water connection. So one possible solution is to remove the valve and thoroughly clean it. I do this by actually disassembling the valve body. Usually it is a split-shell assembly with a rubber gasket at the split line. Just be careful and if you tear the gasket, it can be replaced with automotive silicone gasket maker (comes in a tube). Draw pictures of each step if you need reference for re-assembly.
Dec 23, 2007 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
Do Not Sell My Information Manage Consent
