Canon FAX L-120 Plain Paper Laser Logo
Posted on Dec 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error comm 0001 - Canon FAX L-120 Plain Paper Laser
Anonymous
Level 3:
  • Master 615 Answers
  • Posted on Dec 16, 2010
Anonymous
Master
Level 3:
Answers
615
Questions
0
Helped
228292
Points
2090
Generally this error(Error 0001) is observed while receiving Fax. The Error Code arises when sender not using G3 Fax Machine.So it is a communication error.
I think it helps. Let me know.
Best Regards Fixya Expert Chandrashekhar Bhat
How can i fix error 0001
Xbox-experts.com - Error code 3 RLOD E01 / 0001
https://xbox-experts.com/errorcode/E01/0001/
General info on Error code : 3 Red Lights E01 0001 and how to fix it!. Short circuit in the console/faulty PSU. E-Code / Secondary Error code‎: ‎E01 (No ...
Binary/Hex‎: ‎00000001 / 0x01 -> 1
Primary Error code‎: ‎3 RLOD
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Comm.error(0001)
just press red button few times. That means that there is some kind of interferences in tel line, yours or senders.
2answers
I have a Canon L100 machine that is displaying the message REMOVE ORIG. IN ADF>. However there is no document jam. I have followed the instructions for removing a jam and have also turned the machine...
open the adf cover you should find a little plastic lever which is a paper sensor it is possible that it is stuck in a open position.be sure that the lever can swing freely
I have one irc cannon 3200 , work good but now ,he show me this error code E000733-0001 A NEED HULP , A HEVE ONLY THIS MACHINE IN MY OFICE , I WONNA KNOW WATS HAPEN , EN HOW CAN I FIX UP PLEASE , HELP ME
This error code indicates a communication problem between two electrical modules. The most common solution is to turn off the machine and then disconnect the flat cable that plugs into the back of the reader assembly (behind and below the document feeder), the connector has a button either side of it which both need to be squeezed to remove the connector. Check both ends of the cable and disconnect and reconnect it. Turn back on the power and if this was the comm error your problem will go away. If not, then try disconnecting all of the interconnecting cables between the machine and peripherals.
If none of the above works then you have an internal comms error and possibly a firmware error which will need to be upgraded by a technician.
Good Luck
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
2helpful
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
old marine
old marine
ZJ Limited
ZJ Limited
