I need the the four digit code for a one for all so easy urc-3030b04 my tv is a phillips
    Top Expert:
  • Televison & ... Master
  • 76,455 Answers
Hello
Codes for Philips TV with URC 3030 universal remote control are:-
1223, 1311
Turn on your TV, VCR or Cable Box, depending on the
device you are programming.
Press TV* and release. Press and hold SETUP
until the One For All® Easy 3 Device's red
light blinks twice. Release SETUP
Note: When setting up your VCR and/or Cable Box,
substitute the appropriate device key (VCR or CBL
Enter the
first four-digit
code you wrote
down for the
device you are
setting up. (See
"Looking Up Your
Electronic Device
Code".) If you put
in the code
correctly, the red
light will blink
twice
OK.
Posted on Dec 16, 2010
I need the codes for One For All Big Easy URC-3300B07, to program Samsung Slim TV
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. Surf the site patiently.
Mar 23, 2013 | One For All URC-4330 Remote Control
Big easy one for all urc-3300B07
Check these codes. 0928,0183,0372,0916. If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
I need the code to connect urc-3220 remote rca tv model f25442
028,011,053,073,024 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 21, 2013 | One For All Televison & Video
What is the 4- digit code for a emerson tv when using a phillips universal remote
Please go to this website and select your region.
http://www.urc.philips.com/
Then shows the remote models selct the model which you have, then it opens the page you have both tree and four digit codes for TV/VCR/DVD in pdf format.
Click on it and you can get the code for your TV.
Thanx
Jul 04, 2010 | Philips Universal PH301S Remote Control
I need a code for a phillips t.v. my remote number is urc3300b03 Thank You
To control a Philips TV with a One for All URC-3300, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0054, 1454, 0690
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Dec 25, 2009 | One For All URC-3021 Remote Control
I need to get a code for my urc-3220 for my phillips tv
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Philips TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Nov 11, 2009 | One For All URC4110 Remote Control
Need code for magnavox television with cable (remote control urc-3220)
URC 3220 One for All Big Easy Remote Control
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Magnavox TV.
I hope that helps.
Oct 22, 2009 | Philips TV Tuner Video Capture PCI Card -...
Hi, i have a phillips t.v. and need the codes to it
It is one of the four digit codes listed here 0054 1454 0690
Here is the product page,
http://www.oneforall-na.com/remote.php?type=URC%203021
Here is the Code page
http://www.oneforall-na.com/list_codes.php?db_value=expert4&remote_choice=URC%203021
And here is the Programming steps page
http://www.oneforall-na.com/set_up_remote.php
If this helps, please dont forget to rate it FIXIT!
Thanks,
Charles
Jan 07, 2009 | One For All URC-3021 Remote Control
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
