SOURCE: Black Ink Cartridge error
i ended up putting a color and black cartridge in and everything is fine.
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
SOURCE: black ink cartridge in lexmark fax 4270
can you clarify? This is a fairly straightforward replacement.....Lift up the face of the machine, wait for the carriage to come over and fully stop moving, remove old cartridge and replace with new.....maybe more info on what is actually happening or not.....
SOURCE: put in a new black ink cartridge #32 in my lexmark X5470
Try arrowing down on your screen to maintenance press the tick to select maintenance and then scroll down to align catridges. see if this works
SOURCE: Black ink not printing even tho a new black ink
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Sometimes the ink cartridge carrier
won't automatically move to its loading position even when the printer is on
and the cover is open. Follow the steps below:
1. Unplug the printer from the power
source.
2. With the cover open, hold the
solid white strip that connects from the carrier assembly to the ink cartridge
carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridge.
4. Load the new black cartridge. Close
the cover.
5. Plug the printer back to the
power source.
The ink cartridge carrier moves and stops at the loading
position unless the printer is busy.
