Question about Maytag Refrigerators
MAYTAG REFRIGERATOR MOD#MFI2568AEB CONTROL PANEL LIGHTS ARE FLASHING ON LEFT DOOR. THE ICE CUBE SHUTE FLAP IS OPENING/CLOSING OBVIOUSLY NO WATER OR ICE IS THE PANEL SHORTING? IS THERE A RESET? REFRIGERATOR AND FREEZER ARE MAINTAINING TEMPS. I REMOVED PLUG FROM OUTLET...NO CHANGE WHEN POWER BACK ON
Posted by gabriel_belt on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Posted on Jul 06, 2007
catriver
Ron Marek
  • 878 Answers
SOURCE: Icemaker problems
Woody, This is one of the easier dispenser assy. to fix. The flapper is pretty simple, it clips on to the hinge assy. The hinge assy. has a spring that closes the flapper. There is a selenoid that pulls the flapper open. You can look up the parts on the net to see what they would cost. Flapper-12562701, hinge assy. 67004119, solenoid-12575401,spring 12565502. I don't know if you need all of them, Im not there to see. But if you have some time on your hands you could save a lot of money doing it yourself. Once fixed, you should be good for a long time. Catriver.
Posted on Jul 25, 2007
Anonymous
SOURCE: Maytag Ice20 refrigerator
There's a very detailed guide explaining how to fix this yourself for about $5 in parts. Some basic experience with soldering is helpful.
My Maytag dealer did not offer to fix for free, so I resorted to doing it myself rather than spend $300-$400.
http://www.liny.net/MaytagIce2O.htm
Posted on Jan 30, 2008
Anonymous
  • 145 Answers
SOURCE: Maytag Mod # MFI2568AEB..SER 10962398JC....Problem....all
The capacitors on the high voltage board on the back are out. You will have to replace the board.
Posted on Apr 23, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Posted on Nov 20, 2008
Flashing control panel, ice/water not working, ice release flap constantly opening and shuting
Had the same problem and you need to replace the main circuit board on the back lower left of the refridgerator! Cost about $125.00 for the board and comes with instrutions!
Apr 22, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Mf12568aeb lights flashing and ice door flapping
You will have to call Maytag at 1-800-688-9900...Motherboard is bad. You can pull out the little plate at the bottom of the water/ice dispenser, then unscrew the two screw. Pull on the bottom and the panel should come out. Unplug the white connector on the left. This will stop the flapping of the ice dispenser flap.
Sep 23, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The lights on the Ice and Water Dispenser flash
On left top side of door, remove cap and disconnect wire. This will turn off the control board on front of fridge and fridge will still run. Then follow this link - http://www.liny.net/MaytagIce2O.htm - click on frig picture at right and you will get step by step instructions with parts and tools you may need costing around $20.00 for a do it yourself fix.
Aug 19, 2009 | Maytag MFI2568AE Side by Side French Door...
On electronic control panel and water/ice despensor the ice cube door keeps opening and closing and the buttons on the panel do not respond tempratures of fridg and freezer keep flashing. Tried unplugging...
you have a maytag ice and water in door 3 door refrig???? if so you needs a new high voltage board, its gone bad. locatdon back wall behind the refrig. only resolution is to replace the board..
Mar 16, 2008 | Refrigerators
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Refrigerators Logo
628 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
