Question about Ovens
F8 code on my frigidare double oven after cleaning with self cleaning oven ....know this is in the lock but need to know how to fix it myself left it unpluged overnight plugged back in and its still f8 please help and thank you
Posted by lisanelso537 on
ashburton
  • 417 Answers
Hi
Yes F8 is oven door lock error warning.
You need to physically check the door switches and lock relay, these will be inside the oven casing.
It is probably not the easiest of diy jobs as everything is concealed.
Posted on Dec 16, 2010
F8 alert. What does this mean? The clock and "cancel" buttons work, but no heating buttons work, and self-clean will not operate.
F8 code means your door latch assy needs to be replaced, them you have options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch micro-switch logic is messed up.
Hope helps.
Jan 03, 2011 | Dacor ECD230 Epicure Electric Double Oven
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Self clean
You should have detailed instructions in your owner's manual. Make sure you are moving the door latch (if equipped) from left to right to lock the door.
Sep 26, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
315 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
