Can a 240 volt heater with attached thermostat be installed incorrectly yet still allow the heater to function at less than capacity, say at 110 volts instead of 240 ?
Manual 4 Wire Premium Baseboard/Line Volt Thermostat
Compatible with 120, 240 and 277 vac baseboard heat systems
Simple dial-type mechanical control
Quantity
store iconPick Up In Store
Unavailable at Guam - Tamuning Check Nearby Stores
package iconWe'll Deliver It to You
UnavailableDelivery is unavailable for this product
Your local store: Guam - Tamuning Store Details & Services
Accessories (1)
Product Overview
The easy-to-install Honeywell Manual Electric Baseboard Thermostat works on 4-wire (double pole) electric heat applications (baseboard or line volt) and allows for simple, worry-free operation. It has a simple dial-type mechanical control and is UL and CSA listed for safety.
You will need Adobe® Acrobat® Reader to view PDF documents. Download a free copy from the Adobe Web site.
Compare Similar Non-Programmable Thermostats
Price
$21.99/each
$24.97/each
$44.28/each
null¢ /null
Name
Double Pole 4-Wire Line Voltage Mechanical Thermostat
Digital Non-Programmable Thermostat
Single-Pole 10.4 Amp 120/240-Volt Digital Electronic Non-Programmable Wall Thermostat in White
Brand
Lux
Honeywell
Cadet
Honeywell
Ratings
View ProductView ProductView ProductView Product
Specifications
Dimensions
Product Depth (in.)
1.5
Product Height (in.)
4.5
Product Width (in.)
2.75
Details
Color Family
Whites
Color Family
White
Operation Type
Mechanical
Returnable
90-Day
Shape
Rectangle
Thermostat Product Type
Thermostat Shape
Rectangular
Thermostat Type
Heat Only
Voltage (v)
110/240v
Voltage (volts)
110/240
Warranty / Certifications
Certifications and Listings
1-UL Listed,CSA Listed
Manufacturer Warranty
1 year limited warranty How can we improve our product information? Provide feedback.
the amperage is on the model plate attached to the item
most plug items run a 10 amp circuit breaker for 110 -240 volts as that is the max. amperage allowed for the house wiring and outlet socket
If it is spinning then you may have lost a 110 leg on your electrical outlet that causes the heaters to come on. Start there and work your way back to the dryer. You should have 110 from the ground(lower center hole) to the hot left hole. You should also have the same on the 110 ground to the right hot leg. if you check both the left and right together you should have 220/240 volts. If you don't stop right there and call an electrician. If you do have 110 on each leg as we call it giving you a combined 220/240 volts (it sometimes varies) move up the line to dryer. Either the heater coil has broken (good time to check for good airflow at the vent) or a non resettable thermostat has been tripped causing the heaters to stay off. Poor airflow can cause these two things to fail. The thermostat will need to be replaced if it is the non resettable type. The heaters may have gone too. Those should be checked as well.
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
