Question about Dell Inspiron 1525 Notebook
Problem in charging of dell inspiron 1525...on plugged in power it shows plugged in but not charging.. please give me the solution related to charging of the laptop..
Posted by nagra_kiran on
Chris Hingee
  • Dell Master
  • 32,281 Answers
If the charging LED is on but the battery is not charging then the battery may be worn out.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Posted on Dec 16, 2010
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
HI, Im BALAJI having DELL 1525 INSPIRON. My battery is not charging, it says PLUGGED IN NOT CHARGING. How to solve this issue.?
Replace the battery. If it shows that your are on A/C power and the battery is not charging then replace the battery. It is not holding a charge.
Leaving your laptop plugged in all the time will kill a battery quickly. You need to let the battery get very low then charge it to keep the battery fresh.
Apr 15, 2010 | Dell Inspiron 1525 Notebook
For some reason my Dell Inspiron 1525 wont charge!!. I plug it into the main and the green light comes on the charger lead and it is putting power into the computer but just not actully getting any charge...
This only mean that you have a failing battery and does not hold charge anymore.. battery life can last upto 2years, depending on how frquent you use..
HOpe this helps
Oct 30, 2009 | Dell Inspiron 1525 Laptop
Dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Jun 02, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 laptop not detecting battery
Looks to me like the battery is bad, try another battery if you can and see if the laptop charges it. If it does then the battery is bad, if it doesn't then its something with the motherboard.
May 21, 2009 | Dell Inspiron 1525 Notebook
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 6400 Battery problem
what i would suggest is to check the bios there may be a new flash download on the dell website, my wife has a inspiron 1525, which is plugged in and says not charging, the battery will not go above 0%, but we have had to send it to dell (still under warranty) faulty motherboard. if the bios is up to date, there could be a hardware issue with the battery or motherboard
Jan 25, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1525 Notebook Logo
1,880 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
