Hi
go to this link and download manual
http://files.support.epson.com/htmldocs/cx32__/cx32__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Removing and Installing Ink Cartridges
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1.
Make sure the EPSON Stylus CX3200 is turned on and not printing. The control panel tells you which ink cartridge is low or empty.
2.
Press a Menu button until you see Change Cartridge, then press the Color Copy button. The ink cartridges move to the replacement position
3.
Lift up the scanner
lift up the scanner
continue by going to this link
Pull up the ink cartridge clamp. (The color cartridge is on the right and the black is on the left.)
please rate me 4 thumbs up
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
