Hello To preset a channel or to change a preset channel, follow the procedure below. 1) Press the POWER button to turn on the TV. 2) Press the MENU button so that the menu display appears on the TV screen. 3) Press the CH(annel) ? or ? button to point to "CHANNEL SET". Then, press the VOL(ume) ? button. 4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH". Then, press the VOL(ume) ? button. The tuner scans and memorizes all active channels in your area. ? The TV distinguishes between standard TV channels and cable (CATV) channels. ? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the screen. ? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner will stop at the memorized channels only. ? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case, try AUTO PRESET CH action again in the fine receiving conditions. ? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
To tune the TV either with cable of trerrestrial antena, plug in the cable or terrestrial antena cable to the antenna socket of the TV and do the following.
will appear on the display after the completion of channel scanning.
OK.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers,
for spare parts and service and
Installation Instructions
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
