Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.....
I have the schematics for this TV but the only resistor I see is label as R4114 and its value is 10K ohms, 5% 3 watts.
I could send you the schematics.
Let me know if you required further assistance.
This may help with yours since it was built in 99
Product Safety Information
Product Safety information is contained in the appropriate TCE Service
Data covering models/chassis referenced herein. All specified
Product Safety requirements and testing shall be complied with prior to
returning equipment to the customer. Servicers who defeat safety
features or fail to perform safety checks may be liable for any
resulting damages and may expose themselves and others to possible injury.
First Edition ¾ First Printing
Copyright 2000 ¾ Thomson Consumer Electronics, Inc.
Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s)
Symptom: Shutdown during channel change, shutdown during autoprogram,
dead set or unexplained
random shutdown.
Cause: Incorrect F2PIP Power on Reset (POR) timing
Cure:
Product Support · Mail Stop INH 900
P.O. Box 1976 · Indianapolis, IN 46206 -1976
TV 00-003
Television
TTI TV 00-003
MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP
DATE: July 14, 2000
TOPIC: F2PIP
The following modifications are required to change FPIP POR timing for added
reliability.
NOTE: All chassis manufactured after 950XXXXXX have the modification
installed.
Follow these steps in order.
All CTC195/7 – All CTC203
1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground
(192096). Note: This may require “piggybacking” the resistor on top of
C18114.
MM101 Chassis
C18119.
The next steps are dependent upon the chassis under repair.
CTC195F, F2, F3 chassis
2. Replace R18111 with a 100K resistor (192084)
3. Replace C18118 with a 330nf cap (220132)
4. This concludes the modifications for these chassis.
CTC195/7 (except CTC195F,F2,F3) and all CTC203
2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of
U18100
3. Replace C18121 with a 330 nanofarad cap (220132)
4. This concludes modifications for these chassis.
MM101 Chassis
No further modifications are necessary.
R14109=750ohms 5% 1/4w
(Resistor(750r5%.25W/R14109/179317)
There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it.
If you need the manual, go to
http://www.samswebsite.com/photofact/pf_search.asp
and type in "F31317" into the search field, you will several listings.
If you decide to replace it yourself, here's some more part numbers in case you need them.
Model: RCA\F25422TX41
Symptom: Dead
Necessary parts: Transistor(Q14401)
Main Voltage regulator Q14101
Resistor R14109 open.
Research indicated the flyback transformer most probably bad
\\CTC203AC4\HOT/D2578(Q14101/242224)*
Flyback(14536119A/T14401/244229)*
Main reg(P9NBSO/Q14101/244223)
\Reg(MPS8599/Q14102/147665)
Reg(MPSA06/Q14103/232218)
Hope this helps you.
ZT3000
"Beta tester of "0"s and "1's"
